Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi WS55809 - tv won't stay on
I have a 55 inch Mitsubishi WS-55809. Whenever I go to turn the tv on, it comes on for approx. 3 seconds and then it shuts itself off. The screen doesn't even have enough time to come up. I called the help line and they told me to unplug it for 15 minutes and then try it again. I tried disconnecting the tv from the powerstrip and plugging into the wall directly. I tried disconnecting the tv from the cable box. None of these fixed the problem. Let me know if anyone has any other ideas. Thank you!! Bob
  • 12 more comments
  • Bob Le May 08, 2008
    Dan, Thanks for your response but I really don't have any other details to provide. It was working fine one night. The next day I tried to turn it on and it wouldn't stay on. I'm not sure what to do at this point. I called a service guy and they will cost me $85 just to come out. Thanks, Bob
    Dan,
    I had a tech come out this afternoon. He ended up running some tests on various components and didn't find any issues. He informed me that he would need to take out the main circuit board and take it with him to further investigate. Even though he doesn't know what is wrong with it, he told me that it would run anywhere from $375 to $450 to fix it. I'm not a technical electronics kind of person that feels comfortable fixing this tv on my own. It looks like I might be better off getting a new tv.
    Let me know your thoughts.
    Thanks,
    Bob
  • gmhendy May 12, 2008
    mine too just started last night. my model is the 55807 & is pushing 8 yrs old. I was hoping to get another few years out of it. its been pretty reliable up until this point. i'll be call around tomorrow for advice & service quotes. i'll keep u posted.
  • bmartin70 May 20, 2008
    My tv just went off last night for no reason and now too im having the same problem. I go to turn it on and it turns itslef off.
  • coreysr May 26, 2008
    my tv won't stay on as well I've checked the cord i cleaned it out with a vacum cleaner pluged it back up and all it did was shut off
  • eggscarter May 27, 2008
    yes i to have the same problem the tv turns on fine from the tv or remote but shuts off 2-3 seconds later by itself. the tv is about 6-7 years old if anyone has anything please help.
  • rdhGraybeard Jun 01, 2008
    I have the same problems with my Model WS-55819 - have blown out the dust, just in case it was an overheating problem, with no effect -- please let me know if you find a resolution richkat2006@clearwire.net
  • Anonymous Jun 04, 2008
    I have the same problem with my mitsubishi shutting off after a few seconds. It had done this before on several occasions but evenually started working again. Need help! Kerry
  • Mortymer Jun 05, 2008
    Hi All,
    Same exact problem...6-7 year old set and it will try to turn on for about 1-3 seconds (no picture) and then shuts itself off.
    Worked fine for the past 6 years, but I sure imagined it would last a heck of a lot longer than that!
    It will be the last Mitsubishi product I ever purchase.
    Eric
  • maxblocka Jun 22, 2008
    My Mitsubishi WS55809 - tv won't stay on. Unit turns on for 2-3sec. and then shuts off. any ideas?
    i have also tryed to clean the boards.
  • Steve Tucker Jul 06, 2008
    My Mitsubishi WS-55809 won't stay on. It turns on for about 2 seconds and then there is a fairly quiet click and it turns off. (Same using either remote or button on front.)
    I have also tried blowing out the dust. Someone talked about fuses - I only find one fuse and it is on the AC power input line. If I remove it then the TV doesn't come on at all. When I replace it, the behavior goes back to what I've described above.
  • lbaker4 Jan 28, 2009
    My Mitsubishi set worked fine one day, the next My son pushed the power button and NOTHING. It will not even try to turn on?? Is it finally dead- it is an older set. we just use it in the family room and really don't want to get another one. how do you check fuses in it ??
  • Palsherrie Feb 02, 2009
    We had a similar problem with ours we haven't watched it in 6 mos I took the back off vacuumed it out and one fuse on the center main board in the back of the tv there is a fuse # F9A05 that fuse was burned out and I put a jumper wire on it and the tv came on and stays on we have been watching it for hours now. If this works for you I would have the correct fuse put in it don't leave the jumper wire as perment fix Our TV is a Mitsubishi HDTV 1080 55in rear projection Ours has a diagram on the right side inside the back cover that shows fuse locations.
  • jagerdragon Feb 18, 2009
    the green light will come on and you will hear a click then 3 seconds later it will just turn off
Check the fuses soldered on the board, mine just went out and i have two blown fuses. A 5 amp and a 3 amp 125 volt. Also you can check the diagnostic mode hold the menu and the input on the tv for 5 seconds. If the light blinks twice and then 2 more times that means there is a short (bad fuses)
Posted on Sep 11, 2012
I am another one with the same issue.
Maybe it is the phase of the moon and how the planets have lined up.
Anyone found something?
Ron
Posted on Jul 07, 2008
  • 4,234 Answers
There are a number of reasons for hte set to sut itself down. Usually, the standby light blinks when this happens. It could be as simple as a bad connection or a more severe problem. Please try to post any details about the behavior you can.
Thanks,
Dan
Posted on May 08, 2008
  • ABRsvcs May 08, 2008
    There are a number of things to check. If you are comfortable working insiide the set, I'll list a few things. I'll look up the model tonite and post some details tomorrow.
    Dan
A capcitor is losing it's performance characteristics. Mine is doing the same thing now. This happens to a lot of sets. It's as common as a tuner going out.
Electronics like constant temperatures and humidity. Unfortunately a home isn't going to have that. Also keep in mind that things are built to fail. If they don't then you have to invent something better. Inventing is a lot harder then replacing. It is certainly less expensive for the company.
TVs today usually are good for around 9 years. If they last longer then super. As there are so many different brands now you'll see a lot more inovation and claims regarding leaps in technology to keep you coming back for more. Gone are the days of quality based upon price. Now the price is all about popularity. It's the leming principle. If everybody else is jumping off the cliff then perhaps I should also, lest I miss out on something.
An old woman lives in a small rural community about 18 miles East. She called to complain that her pictures were bad. As a cable guy it was my sworn duty to go forth and see what's up... I looked over the set while the woman told the story of how she had ordered the first color tv in the area. She bought it at Western Auto and Appliance. It had a wooden cabinet and a small speaker below the old dials. She had been watching if for over 30 years. She had given up on the old girl and asked what brand she should buy to replace it. I told her to give me a little more time to look things over. I was really just curious about the set and all the adjustments you could make back then. Now you have to rely on a "technician" to fix it. Well, after giving all the knobs, switches, dials, and buttons a carefull inspection I found one small recessed button tucked away, far from any of the other adjustments. It simply said "RESET" and plain black letters. Could it be that simple?
As if God himself had directed me to this poor soul's home to bring salvation to her television viewing, I could feel the influence of some intelligence, some power, course through my body and into my hand clutching a tiny screw driver. I thrust the insignificatn implement deep in the darkness behind the word "RESET" plunging the smallest of black buttons till it would yield no more. At once an explosision of joyfull praise permiated every sqaure inch of the mobile home's living room. The 80 year old woman looked at me like I was holding a large check from publisher's clearing house. The TV was brought back to life, as if, by a miracle. Somebody sitting at a test bench in a research and delvelopment department within the bowels of RCA. decided that a "RESET" button would be a good idea. For that I am willing to bet, they were fired or promoted out of that capaicity.
So, to those of you experiencing this problem. If your set won't stay on, or if it shuts off as soon as you push the power button, I say to you go forth with credit card in outstetched hand and with the other hand cover you bum, because TVs are really expensive nowadays.
Posted on Aug 25, 2008
Ws55809 tv picture bows at top and bottom. Also has shadows. Is it the bulb and where do I get one.
You have a convergence problem. The 3 picture tubes are fine. The small signal module needs reworked. The board with all the rca jacks.
Nov 29, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws 55809 convergience
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Jun 03, 2009 | Mitsubishi WS-55809 55" Rear Projection...
TV power will not stay on.
Not worth to fix.Either power supply,sensor or convertion board are too costly for the part.Buy a new TV.
solutiondoct
Nov 12, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 Shadow
check the "close caption" option on the menu should be of
Oct 14, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Tv vertical lines
Remove back .... lightly tap modules with plastic screwdriver
handle to isolate where bad connection is.....pull module or
chassis...solder,then repeat until problem solved......T.
Dec 24, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55 inCH tv
best way i would trouble shoot this would be to get a can of freeze from radio shack and spay the tuner if the problem comes back you know it's the tuner if not spray IC one at a time till the problem happens.
Dec 11, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS55809 won't start up.
It's been my experience that this is usually cause by a blown fuse. Check all the fuses on the boards inside the TV
Oct 22, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitssubishi ws55809
Still need help ? Check fuses on power board and let me know.
..........................T.
Mar 31, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
4,222 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
