Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
I dropped my usb hard drive when it was not connected. It slipped out of its leather pouch and fell from my work desk onto the office carpeted floor. Now it doesn't get detected by my notebook. When I plugged it in, it draws power and makes the usual clicking and spinning noises that one notices on a hard drive. In one instance, it even makes a loud beep. It feels like the drive was trying to do something. The device manager deteccts it as an USB device but has a "code 10" problem. Is the hard drive dead? It has my working directories and I am losing hopes...
  • 6,831 Answers
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Posted on Dec 08, 2010
Question re: Avolusion HDDGear Pro 500GB 16MB Cache 7200RPM USB 2.0 External Hard Drive: it fell off my desk onto a carpeted floor and now will not allow me to access my data on it. It makes a noise as if...
The bad News, when it fell it most likely knocked the heads or disk out of alignment or broke something inside. Good News - It may still be possible to recover the data on it but that will have to be done by a data recovery specialist company that can take the drive apart and read the Disk plates individually to reconstruct it. Bad News -That process will most likely cost more than the computer did as it is a very specialized field and requires very special conditions.
May 22, 2011 | Computers & Internet
I accidentally kicked my 1tb buffalo external hard disk and it fell the usb connection has been remove and when i connect it again the hard disk start to beep and the computer doesnt recognize and detect...
First try a different usb cable. The cable or the cable connectors may have been damaged as a result of the fall.
If that doesn't work and you are certain that your PC does not recognize the drive, then It appears to me that the fall damaged the delicate mechanical devices inside the drive and you will have to replace it.
Hard drives cannot withstand rough handling. If a hard drive is only dropped about 1 or 2 feet and it lands on a soft surface such as a carpet it MAY survive the fall. But if one falls from a higher elevation, (say 6 feet) onto a hard surfaced floor, it's almost a sure bet that the drive's internal mechanisms are permanently damaged.
To find out for sure, take it to a PC technician and have it tested. It should only cost you a few dollars.
If you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Dec 09, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
I dropped my hard drive and now it wont unlock.
Bdfreo you do anything, try the device on anopther pc. see if it works then youhave nothing much to worry. if it does not, then i guess you have to go for data recovery
May 05, 2010 | Western Digital My Book Essential Edition...
My hard drive is making funny noises and isnt recognized
If you get it going, you should immediately store all the data on another drive
Aug 19, 2009 | Western Digital My Book Essential Edition...
Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
Jul 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
HARD DRIVE NOT DETECTED
I would just try and come out straight to you, that your harddrive has very much likely to have crashed. Hard Drives are generally Very Fragile because of the Tiny Read/Write head that is inside.
The moment it drops on the floor it might have got broken. and that is why you are hearing the funny noise...although it will still keep spinning because the voltage is still being supplied onto it, but you might not be able to read or write anything onto it.
Sorry.
Hope this helps.
Goodluck.
Jul 11, 2009 | Hitachi HDT725050VLAT80 500 GB EIDE Hard...
Hard drive crashed
yes you are right.the disk spinning it in is got damaged due to falling.its gone.the new hard disk is required.this will not work. thanks.
Slightly dropped seagate external hard drive, recover data??
please use stellar phoneix software
that will do your job surely
Mar 16, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
155 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
