Question about Janome 1017 Mechanical Sewing Machine
Every 4 or 5 stitches the bobbin thread fails to catch the top thread resulting in skipped stitches
  • 161 Answers
Double check needle position and needle type. It will also do this on stretchy material, do to material catching on the thread
Posted on Sep 13, 2010
Skipping right side stitch on a zigzag stitch, so when i am running a zigzag stitch when the needle goes through the fabric and comes back up it pulls the stitch back with it ??
check your bobbin and is the needle good and sharp and the proper length.make sure its not bentthe tiniest defectt n a needle can mess up any stitch.
how does it work on regular stitching.
most problems with machines involve.bad needles incorrect threading of bobbin or spool,dirty bobbin,incorrect needle.
it sounds like the needle isnt catching the bobbin thread.
hope this helps
Apr 05, 2017 | Sewing Machines
Skipped stitches
Skipped stitches could result from several different origins. First, easiest, and least expensive thing, try a brand new needle. However, if it is failing to pick up the bobbin thread all together, then it is probably out of time (search for sewing machine timing or take it for service).
Here are other suggestions for intermittent skipping:
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Basic Maintenance Tension Skipped Stitches
http://www.sewingreviews.org/what-to-do-when-your-machine-starts-skipping-stitches
Jan 03, 2017 | Sewing Machines
Machine. Skips stitches and the thread breaks in the top tension.
First, install a brand new needle. Confirm that you are using the correct needle for the thread and fabric being stitched, ie the needle eye could be too small for the thread, the fabric is coarse or sticky causing the thread to wear/fray causing breakage, the needle is blunt or bent, a ball point needle is being used on woven fabric or vice versa...
All About Needles
Second, remove the thread from the machine. Always RAISE the presser foot and rethread from the beginning--make sure the correct thread pathway is followed (consult the manual).
Verify that the tension is not set too tight. The tension is correct when both upper and bobbin threads meet in the middle of the fabric without any puckering of the fabric.
Use good quality thread--avoid old or bargain bin variety. And, use the same thread for the upper and bobbin. Some thread brands may work better than others in your machine. You may need to experiment to find ones that work best.
There is also the possibility that there is a nick or burr somewhere that is catching the thread. You can wrap your index finger with old hosiery (or similar fine fabric) and rub around the thread path, in the bobbin/hook area, needle plate, etc. A small burr can be smoothed with a fine emery board. A big burr may require replacement of the part or service by a technician.
Apr 23, 2016 | Sewing Machines
I have a futura ce 150 and my bobbin thread won't catch
Are you able to bring the bobbin thread to the top of the needle plate, but it's skipping stitches, or you can't "catch" the bobbin thread to start sewing at all.
If you can't "catch" it at all, your machine's hook is no longer synchronizing, and you will need to have it retimed by a technician. The good news is, timing is not something that is unique per manufacturer, which means ANY sewing machine technician should be able to do it.
Sep 25, 2014 | Singer CE-100 Futura Computerized Sewing...
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
My New Home skips stitches. I have cleaned it, changed needles, adjusted the tension and tried different bobbins .
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
it's also possible that the machine could be slightly out of time
Aug 29, 2012 | Sewing Machines
Keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Asinger model 5050 will not make stitches,checked all points,
your machine sound like it is out of time you need to take it to a service center
Jan 15, 2009 | Singer 5050 Mechanical Sewing Machine
Won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Jun 25, 2008 | Janome D'cor Excel 5018
Janome 1017 Mechanical Sewing Machine Logo
170 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
