Question about Dryers
The tumble dryer is working but not getting hot.
  • Dryers Master
  • 17,129 Answers
It this a electric type if so check for the failure of the connection to the heating coil cartridges or the coil by itself. Check power from the switch to the coil.
Posted on Aug 30, 2010
Dryer turns on but does not tumble, sensing light is on. The last of laundry was incredibly hot. If it's the thermal fuse, wouldn't the dryer still tumble, though?
Not Tumbling means that the belt has slipped or broken, the over heating could indicate that the motor is burned out and the fan that moves the air is not working.
Jan 19, 2016 | Dryers
Dryer won't tumble.
check the belt............if ok then could be the motor ..........cheers
Apr 15, 2014 | Whirlpool WED9600T / WED9600TA / WED9600TW...
Tumbler is making wierd sound but the drum still turns and it gets hot
drum rollers/glides, may be the idler pulley:
ttp://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Miele T8005 Tumble Dryer
My drier doesn't get hot but it still tumbles
The elementf2f2ac3.jpgor if that is ok look for lint blockage that can blow dryer thermal b3b8df4.jpgsafetys 87e64db.jpgIf that is good and you have 240 volts ac to the machine then the timer may have a bad contact c92b935.jpg5aee1f0.jpg
Jun 22, 2010 | Whirlpool LER4634J Electric Dryer
Tumble dryer not getting hot
Likely to be a thermostat or heater element problem.
These are located at the rear of the dryer, behind a removeable cover, but you will need a test meter to check them out.
Hope this helps.
Dec 15, 2009 | Hotpoint Dryers
Dryer tumbles but no heat
I believe this unit has a hot-surface ignitor, and they work great, but do go bad eventually. The easy way to tell is to visibly see if the ignitor is operating during startup... can you get to it?
The hot-surface ignitor is easy to replace- (be careful not to touch it with fingers - like with halogen bulbs)
Dec 15, 2009 | Dryers
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
Zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
GE Dryer makes deep sounds when hot and tumbling
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
