Question about Hawking AR740 ADSL Router with Modem
Hawking AR740 This AR740 is replacing a router/modem that went bad. I got it used with no documentation. The exclamation point is gone and I can telnet the router but I cannot enter a password and I cannot connect to the internet. I am using Windows XP. The ethernet light is on. I changed cables but didn't help. I forced the lan card as you instructed but didn't help.
  • 77 Answers
Hi!
Is that the router's login screen that you're talking about? Did you set a password at the AR740 before? Try possible passwords that you'd commonly using.
Try this link & hopefully this will help you..
http://www.hawkingtech.com/support/details.php?CatID=33&FamID=79&ProdID=101
Posted on May 08, 2008
Hawking Extender- Connected to WiFi but cannot access Internet
First think I always do is Reset Linksys Router and disconnect extender. Then turn off all security on router. Do soft reset on ipod. leave extender off and see if you can connect to the linksys. If you can then plug in extender (still with security off) then see if ipod connects to extender.
you might have to soft reset ipod again once you connect the extender.
if that works. reset security. Let me know how that goes.
Jan 01, 2010 | Hawking 802.11g Wireless-G Range Extender
I have a 2wire HG-B modem/router and I want to extend my wireless network by using a Hawking HWRN1A router. How do I configure my 2wire with my Hawking router, so it can work?
this hint is only possible if your hawking can be used a an access poit. if yes then try try the following:
connect you adsl line into your modem/router,
connect the lan cable of your modem into a switch
connect both your PC and Hawking into the switch
have your modem/router provide DHCP and DNS
configure your PC to gte its ip address and DNS dynamically
configure your hawking access point to also get its dns and dhcp dynamically (do this by getting into the hawking http page configuration, or telnet if you are good with commands)
now set a wireless lan with WPA or higher through your hawking.
there you have it.
doubts??? i have more solutions
Mar 23, 2009 | 2wire Computers & Internet
I recently purchased a Hawking HSB2 Signal Booster. Two years ago, my son installed a Toshiba Cable modem(PCX2200)and a Belkin Wireless Router(model#F5D7230-4)for Camcast High Speed Internet. The Router...
Booster will only work along with access points in your case the belkin wireless router - you have to connect the device to the router not to the windows xp pc
if you know how to configure and the device are compatiable to each other and allows bridging or can configure as your access point client then you need not wanna to get it connected via wire or T568b standard ethernet cable otherwise you have to connect with this cable will enchance the wireless activity
Wireless signals can go down its strength by any magnetic activity, oscillations such as microwave, powerful steel/metal frames and check your anteena position keep in different direction and check your pc wifi signal strength.
Interlink between your router and booster with utp cables gives you steady flow of data and full band strength.
Aviod using two company devices change the router to Hawking
Thanks Hothawk
Jul 24, 2008 | Computers & Internet
Hawking AR740
I see. I'm not really familiar on how to configure it. As far as what I've checked at its datasheet, it didn't mention that you can use IE to configure it. Have you been to its web ui before? What did you use to access it?
May 08, 2008 | Hawking AR740 ADSL Router with Modem
Additional question
If there's a reset button then I would advise you to reset it.
You can also download the data sheet before doing the reset:
http://www.hawkingtech.com/support/details.php?CatID=33&FamID=79&ProdID=101#Datasheets
and according to the data sheet, your device came with a setup cd. Try to re-run the cd if you still have it.
May 06, 2008 | Hawking AR740 ADSL Router with Modem
The router is not communicating with my pc
Hi there!
The limited or no connectivity problem is commonly caused by some of these factors:
1. router not giving out an IP address (no DHCP)
2. Incorrect network key or passphrase if you enabled wireless security
I want to help you out and I need to ask you these:
1. How many computers do you have?
2. Do you have a wired or wireless computer?
3. Is it laptop or desktop?
May 04, 2008 | Hawking AR740 ADSL Router with Modem
The router continues to show up to 5 computers as on line, when they are not even with 2 of the 5 having the same mac address. this seems to be causing the security to fight what appears, itself. it takes...
We are always available at Avast Antivirus Tech Support Phone Number1-866-877-0191 on 24*7 hours. You can completely free to contact us on Avast Antivirus Tech Support Phone Number 1-866-877-0191. You will get the best resolution of all issues. Just call here anytime.
http://resolit.us/Avast-Antivirus-Support.html
Aug 08, 2017 | Hawking AR740 ADSL Router with Modem
No Wireless Connection
Can your laptop connect to the internet using an ethernet cable that is connected to the Hawking router?
Check to see if your laptop has a wireless on-off button or switch on the outside of the case. It may even be a combination of two keys "Fn + F2" on some Gateway laptops. When you flip the switch an indicator light of some kind will tell you when your turning the wireless radio on and off. Flick the switch until you're sure the radio is on and try to connect.
Let me know the answers to both of these items.
Dec 24, 2007 | Hawking Wireless-G HWR54G (603992506064)...
Hawking AR740 ADSL Router with Modem Logo
37 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
