Question about Mattel Tyco R/C Air Blade Hovercraft - Blue
How long do you have to charge the 12 volt battery for?
How long to charge the 12volt battery pack, using a 45va step down from 240 uk to 110 volt
Posted on Jul 21, 2011
12v battery won't charge replaced inverter and battery got 13.6v coming out of the inverter and only 12 at the battery
inverter problem as it is a required voltage of 14.5 volts to charge a 12 battery ( a fully charged battery is actually 13.2 volts as 6 cells of 2.2 volts each = 13.2 volts )
Jul 24, 2017 | Inverter Electronics - Others
Yamaha 450 Kodiak battery not charging, new battery, volt meter not showing any voltage going to the battery
Hi Brian, get a digital volt meter and start the ATV measure the voltage at the battery or at the alternator it should read around 14 volts when charging, if it reads 12 volts the charging system is not working, check or a blown fuse or broken wire, if you can access the alternator directly measure at that point. It takes 14 volt output from the alternator to charge a 12 volt battery
May 06, 2017 | Yamaha 2005 Kodiak 450 Auto 4x4
2004 polaris ranger battery not staying charged when operating but when engine is off battery not affected cutting out and dying what could be the problem?
battery is being drained as it operates and not taking charge
check tightness and clean both terminals and cables
how old is the battery
may have a dead cell ..wont take charge
check the charging input to the battery with a volt meter
has to be above 12 volts
if lower or equal to 12 volts ...no good
the charging stator inside the engine needs testing or repair or replace
stator is another word for an alternator or a generator
why it plays up
best guess the ATV if a 12 volts system wont run on 11 volts
Oct 13, 2016 | ATVs
Charging system failed. Why is new alternator output ranging between 11 1/2 and 12 1/2 volts?
11 1/2 to 12 1/2 is not charging . That's less then battery state of charge , Battery stat of charge should be 12.6 volts , when charging with a volt meter you should see 13.1 to 14.1 volt at the battery posts . Is there a battery symbol lit on your instrument cluster ? Is there battery B+ voltage at the wires hooked to the alternator How to Test an Alternator
Feb 18, 2016 | 2001 Kia Spectra
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
How do you charge the 12 volt battery with a 6 volt charger
  • A 6 Volt charger will charge a 12 Volt battery, it will just take twice the time to get the 12 Volt battery to full charge as a 12 Volt charger would take. V*I=W. It will take up to 36 hours to get a full charge from near dead but it will work just fine.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Electric Kid Trax C6 Corvette Ride On
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
My batteries are struggling to charge do i need new ones
Harold Do you mean that they won't fully charge or won't charge at all. If you have the small 12/12 batteries then they do not last as long as the U1 batteries (bigger) If you have the U1 batteries check the voltage of the batteries with a volt meter Fully charged should read over 12 volts and up to 13.5 volts. Also check your charger to make sure that it is charging with a voltmeter you can measure the voltage aith the charger plugged in and you should be reading over 13 volts on each battery. Hope this helps you
Sep 07, 2010 | Pride Health & Beauty
Wont keep a charge
You should be able to get over 12 volts from the charging system of the lawnmower. I would think once it is running, you should get 12.8 to just over 13 volts dc to adequately charge your battery. If you have less then 12 v power output from your chargiing system, well then the charging system is not working properly.
Of course, if the battery is defective and wont hold a charge, you can test that be taking the battery out of the machine and checking the voltage. It should be 12 volts or slightly better. If you let it sit overnight and it drops substantially, well it is likely not holding a charge and draining internally. If it does not have 12 volts to begin with and your charging system is ok, well then it is likely defective.
Also, you can use the glass hydrometer made for batteries to draw up some fluiid and check against the colour scale.
Each cell on a battery is 2 volts, so 2 volts times 6 cells is 12 volts. So if one cell is bad, then they all become bad as the battery needs a total of 12 volts to operate.
Some gargages will test your battery for free if you buy the new battery from them.
Sep 21, 2009 | Briggs & Stratton Garden
24 volt charging problems .2 12 volt batteries 1 battery 16volts and the other about 9-10 volts
A 12 volt battery is actually 13.2 volts fully charged. If you are reading 16 volts, you are probably getting extranious voltage from the system somewhere, especially if the vehicle is running when you check the voltage. The alternator will put out about 15-18 volts to charge the battery normally, and yours may put out 28-32 volts to charge them in series, but the batteries, when disconnected, should never read more than about 13.2 volts each. Typically, it will read about 12 1/2 volts when disconnected. COMPLETELY DISCONNECT BOTH OF THE BATTERIES. If you still read 16 volts when it is disconnected, you must have a bad meter because the battery can't produce that much voltage, no matter what. (Six 2.2 volt cells connected in series inside the case.) Put the meter on a known good battery on another car that is not running and see if you get the same reading. It sounds like the other battery is almost dead, regardless, and it sounds like your series/parallel switch may be malfunctioning. (That is the switch that puts the battery in series to run the 24 volt starter, then puts the batteries in parallel to run the remainder of the vehicle on 12 volts. This is all assuming that you have a diesel vehicle with a 24 volt starter and that is why you have two batteries.
Aug 19, 2008 | Toyota Land Cruiser Cars & Trucks
Mattel Tyco R/C Air Blade Hovercraft - Blue Logo
251 people viewed this question
Top Mattel Toys Experts
thegtw
Nikki  Mclean
Nikki Mclean
Tracy E
Level 1 Expert
Are you a Mattel Toy Expert? Answer questions, earn points and help others
