Question about Apple iPod touch
When ipod touch powers on only white screen comes up
  • 3,530 Answers
Welcome to Fixya
This problem is called the white screen of death. To solve this, you should press the Home button and the Power button together for about 30 - 40 seconds. This process is called hard reboot. You can also try to restore the factory settings by plugging the device to you computer and restore it using itunes.
Thanks
Posted on Jul 03, 2011
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
Jan 27, 2013 | Apple iPod touch
My ipod Touch has an issue where all that is on the screen is a blank whiteness. I can turn the screen off by pressing the power button but can't turn the device off. When I press the power button again or...
This will need to be sent in for repair there is nothing you can due if you tryed to restore it by holding the home + power down until it resets, if its still white then there is indeed a issue.
Jun 25, 2010 | Apple iPod touch
IPod touch Digital Media Player: the screen is completly white and fozen will not p...
Try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod from within itunes.
May 06, 2010 | Apple iPod touch
My ipod touch comes on however a white screen appears,instead of regular display menu
To fix the iPod Touch white screen of death the solution I've used is press in the sleep/wake button on the top left of the device, and the big circular home button on the front face on the bottom. Do this for roughly 10 or more seconds and the device should shut down/off. Give if a moment and then restart the device.
Mar 06, 2010 | Apple iPod touch
My ipod screen turned white please help
Try doing a full restore by putting the ipod into recovery mode. Make sure to set it up as a new iPod and not use a backup.
Oct 06, 2009 | Apple iPod touch
First gen i pod touch, white blank screen
  1. Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
  2. Connect to the internet and install the latest version of iTunes from the Apple website.
  3. Make sure your iPod Touch is connected to your computer.
  4. Pick "iPod Touch" in the Source pane of the iTunes program.
  5. Click on the Summary tab.
  6. Choose "Check for Update."
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch.
  8. Complete an Advanced Restore
  9. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  10. Plug the iPod Touch into your computer.
  11. Power on the iPod Touch.
  12. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  13. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  14. Return to the above section and follow those steps to restore your iPod Touch.
Sep 25, 2009 | Apple iPod touch
When i turn on my ipod, there is just a blank white screen
Ooh, blanks WHITE screen normally means there is a hardware break, try putting it into recovery mode:
Hold the Power and Home buttons together for 10 seconds, release the power button and continue holding for another 5 seconds, then plug into iTunes and restore it.
If that doesn't work I hope you have warranty because it'll be a hardware error :(
Sorry I ccouldn't have better news!
Thomas
Aug 23, 2009 | Apple iPod touch
Droped iphone, screen is only white, touch screen works.
put it in DFU mode while connected to the computer. to do this, hold the home and power buttons for 10 seconds and then let go of the power but keep on holding the home for 10 secs. the screen will be black and nothing will show up. go to itunes and click on your ipod on the left. then click restore. this should work.
Apr 22, 2009 | Apple iPod touch
Ipod touch 2 gb screen went white
that happens sometimes. whenever it happens, hold the power and home button until it turns off. then turn it back on
Mar 25, 2009 | Apple iPod touch
My itouch screen keeps going white
push the off button and the O button and hold it in untill it fixes
Jun 29, 2008 | Apple iPod touch
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
