Question about Hitachi Heating & Cooling
Dear Sir/Madam, We have purchased 4 new split ac of 2 ton from M/s Vishnu Parshad Singhal & Sons, Kurukshetra (Haryana) but one indoor unit have some problem like leakage of gas after many times of reminders throughout mail or telephonically Mr. Singhal (Dealer) has changed the defected AC from other one but this ac is also not working, now dealer also not picking the phone. Pls tell us what is the company labiality in this seen? Regards, Anurag Deepak 9996544521
4 Suggested Answers
james3751
  • 614 Answers
SOURCE: Water leakage from internal unit of split AC
Draim pans do get dirty and partialy block drain pan. If possible take a shop vac and gently **** out the drain line. This will pull the restriction out of the line and help clean drain pan. Rusty
Posted on Jun 07, 2009
  • 9 Answers
SOURCE: Hi I have 1.5 ton samsung split AC. the problem is...
the water comes from the coil, start there make sure there is no obstruction coming out to your condensate line and make sure its properly pitched.
Posted on May 22, 2010
SOURCE: I have purchased one Samsung
You have a LEAK from installation that must be found & repaired before any more GAS is added to the system.Then it will normaly need a little gas every 3 years.
Posted on Sep 29, 2010
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
I have samsung split ac 1.5 ton 2.5 years old when am switch on the ac the indoor unit is working when it tires to on the out door unit after 3 minute delay suddenly the ac is restarting but the out d
Make sure all of the pressure switches are closed on the low voltage control circuit on the outdoor unit. If any are stuck open, the compressor will not kick on. Or just push the compressor contactor in with an insulated screwdriver to ensure the compressor does actually work.
Dec 28, 2014 | Samsung Heating & Cooling
Error code E9? in godrej split 1.5 ton AC
Godrej 2 ten indoor despily e9 cood
Mar 17, 2014 | Heating & Cooling
Out door is not working
Check for communication from indoor to out door.Check power in out door unit. If not, check the following.
Keep cool mode and temp setting minimum 3 degree less than room temp.
Check indoor unit return air sensor. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace air sensor
Check Indoor Pipe Sensor Disconnect from PCB and measure resistance. Pipe sensor = 5kOhm at 25C. If not replace pipe sensor.
Thanks and hope helpful?
Feb 04, 2011 | LG LS-L1210CL Mini Split Air Conditioner
I am looking to buy a mini split ac/heating 1 ton unit. I want to know how high from the floor does the unit have to be to cool and heat a 10 x 20 room?
Hi, when you buy your split system, the indoor unit will mount on your wall off off the floor a distance that the factory has made it for. With an 8' to 10' ceiling, it would be about 7' off the floor. This all depends on the refrigeration plumbing coming from the outdoor condenser to the indoor unit. It will tell you all of this on the installation kit for this unit, as the plumbing for the freon pipes are already pre-made for a certain height. A 1 ton, (12,000 btu) unit will have no trouble cooling a room of this size, so check with the manufacture on the height it will be.
Shastalaker7
A/C, & Heating Contractor
Jan 04, 2011 | Goodman Heating & Cooling
I have problem regarding water tapping in indoor unit of split a.c.
dear sir /madam
please do every week clean your split type a/c,s filter it,s main coz who responsible for block the drain water line and after that split indoor drain ac unit drain water from inside of the unit , try to find out the drain water line of indoor unit of air conditioner the make clean it and also check it i mean keep some fresh water for make test its drain line it have been open or not if water is going easily then ,it,s ok
it,s up tp you if you think you can do it or contact to it,s technician for do solve this problem.
thank you for using fixya for get solution
hope answer the question
please vote!
Jul 07, 2010 | Whirlwind FH-778 Air Conditioner
Hi I have 1.5 ton samsung split ac. The problem is to solve the water leakage in the indoor unit. Kindly advise
May 19, 2010 | Samsung AS1293L Air Conditioner
How to get the logic card of 5610 and the cost of
purchased the HP 5610 Office jet Printer and the warranty is over now. I got the problem and the loca dealer has refused to repair the same due to non availability of logic card. Please suggest me how to get the logic card of 5610 and the cost of logic card. I belogns to Kurukshetra(Haryana). Pl. suggest me.
Dec 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Heating & Cooling Logo
49 people viewed this question
Top Hitachi Heating & Cooling Experts
ka4iup
ka4iup
bobalix
richie46
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
