HP Compaq 8510w Mobile Notebook Logo
Posted on Aug 30, 2010
PC Recovery Progress stays at 0%. I'm trying to format my laptop to factory setting but it appears to hang at 0% of the process. Please help. Thank you
Bob Rambo
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 9 Answers
  • Posted on Nov 20, 2010
Bob Rambo
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
9
Questions
Helped
2616
Points
23
Try restarting your laptop and press F10 to enter computer set-up.
Go to the security tab and select disk sanitizer.
This will wipe your harddrive. After the sanitizer finishes you will be able to format and install your OS
What F? Key do I press to restore my Fujitsu Siemens amilo L7320GW
Fujitsu simens back to factory settings
Downloads & Disks Regarding The Reset Factory Settings Fujitsu Amilo Li 2727
http://www.user-guides.co.uk/download/reset/resetfactory/reset-factory-settings-fujitsu-amilo-li-2727.html
Fujitsu Laptop to Factory Settings
Restoring the factory settings on your Fujitsu laptop is a great way to get rid of files associated with programs that have been removed from your computer that are taking up space and get rid of pesky viruses that you can't remove from your machine by any other means.
Restoring the factory settings on your laptop can also help resolve problems with an unstable laptop.
You should also restore the factory settings on your laptop if you plan on selling it or giving it to a family member or friend.
Restart or turn on your Fujitsu laptop. Press "F12" repeatedly when the Fujitsu logo appears on the screen to be redirected to the Boot Menu.
Highlight "Recovery and Utility" using the arrow keys on the keyboard, then press "Enter."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files.
When the files have been loaded, the System Recovery Options window will be displayed.
Select a keyboard layout, then click "Next." The Operating System dialog box appears.
Choose "Use recovery tools...," then click "Next." If prompted, type your administrator password, then press "OK." The System Recovery Options window will appear again.
Select the "Recovery" tab, then click "Restoring the Factory Image (only C:\drive)."
The restoration process will begin, and the laptop will be restored to its original factory settings.
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen.
Begin personalizing your copy of Windows.
Using Boot Disc
Highlight "CD/DVD" using the arrow keys, then press "Enter."
Place the boot disc that came with your Fujitsu laptop in the optical drive, then click "OK."
A progress bar will appear at the bottom of the screen while the computer is loading the recovery files. When the files have been loaded, the System Recovery Options window will be displayed.
Click "Next" when the Operating System dialog box appears.
If prompted, type your administrator password, then select "OK."
Click "Recovery and Utility" when the System Recovery Options window opens, then select the "Recovery" tab.
Click "Restoring the Factory Image (only C: drive)."
When the process is complete, the computer will automatically restart and boot up to the Windows Setup screen. Begin personalizing your copy of Windows.
Saving and recovering your factory and system images.
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/HDD Restore Generic-Multi-lang B6FJ-3031-03EN-00.pdf
Restore hp pavilion dv7 1464nr to factory settings windows
Step 1:
Which operating system ?
Restore Hp laptop factory settings without a Restore Disc Turn on the HP laptop. When the blue HP screen appears, press the "F10" key repeatedly until the "Recovery Menu" appears. A progress indicator informs you of the time before the recovery process is to take place. Click "Next" in the Recovery Menu. Decide whether you want to perform a nondestructive or destructive recovery. A "nondestructive recovery" does not format the laptop's hard drive or erase any personal files on your laptop. However, a "destructive recovery" formats your laptop's hard drive and erases any personal files you have on your laptop. Click "Yes" to execute a "Normal, nondestructive recovery." The restore process begins and your laptop restarts. Alternatively, to execute a destructive recovery, click "Advanced." Click "Yes" to start the "Destructive recovery." The restore process begins and your laptop restarts.
Restoring with CDs Back up all crucial user files if you are able to do so. If your computer will not burn CDs, use flash drives of 4GB or higher to store your data. Alternatively, you can use your network to transfer files. You can then back up your data to CDs at your leisure. Detach peripheral devices such as removable media drives, USB drives and your printer before recovering. Also remove any additional hard drives by disconnecting the cable from the back of the computer. Leave your monitor, mouse and keyboard attached to the computer. Shut down your computer. Place the first recovery CD in the CD drive. If your recovery files are written on a partition, you may be able to select system recovery from the splash screen and your computer starts. Select the recovery option you would like to use. To perform a destructive recovery, click the "Advanced" menu option. Select "Destructive Recovery" and click "Next." To perform a non-destructive, or system, recovery, click "Next" from the opening screen. Watch the computer while it is recovering to the factory settings. Watch for any errors, as the computer will wait indefinitely for a response from you, slowing down recovery time. Also, you may need to insert additional recovery CDs as the recovery program requests them. b> Restoring With Recovery Manager Click the Windows "Start" menu, type "Recovery" in the Search field and press "Enter." Click "Advanced Options," choose "System Recovery" and select "Next." If you are prompted to use Microsoft's recovery program, select "No." Choose the option to back up your files, if you haven't done it already. Once that is complete, choose "Next" to begin reformatting the drive and returning the system to factory settings.
1helpful
Toshiba no bootable device--insert boot disk and press any key
try booting from a Windows installation disc. Choose the repair installation option. If this does not work, you may have to erase (format) your whole drive and start over again by reinstalling Windows from scratch.
Before erasing the drive, you might want to pull it out, put as a second drive in another working computer or inside a USB hard drive case and download all of your information from it. Otherwise you may have a mess on your hands with lost data/documents/photos.
1helpful
Return msi ge620 to factory settings
Use the recovery partition on your MSI laptop to recover its original factory settings. Recovering your MSI laptop to its original factory settings will resolve problems with instability that you may be experiencing as a result of missing system files that were accidentally deleted. Recovering your MSI laptop to its original factory settings will also completely remove any viruses on your computer's hard drive that you were unable to remove with anti-virus software. Fortunately, you can wipe all of the information off your laptop's hard drive and start with a clean slate.
Turn on or restart your laptop. Press "F3" repeatedly when the MSI logo appears on the screen during the boot process to be redirected to the "Windows Boot Manager." Highlight "Windows Setup [EMS Enabled]" using the arrow keys on the keyboard. Press "Enter" to access the recovery partition on the hard drive of the MSI laptop. The "System Recovery Option" dialog box will appear on the screen. Click "MSI Recovery Manager." Click "OK" when a message appears on the screen notifying you that your computer will be restored to its original factory settings. Click "OK" when a message appears notifying you that the hard drive will be formatted to begin the recovery process. A dialog box with a status bar will appear to indicate how much time is left in the recovery process. Depending on the of your hard drive as well as how much personal data needs to be erased, the recovery process could take up to 45 minutes. Click "OK" when a dialog box appears on the screen indicating that the recovery process is complete. Your laptop will automatically restart and boot up to the Windows setup screen, where you can begin personalizing the settings for your Windows operating system. Hope this helps.
b>
Deleted pre-installed installation software. What do I do?
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state.
6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
2helpful
Where do I find the recovery partition on my toshiba l645d laptop with windows 7?
The recovery partition is basically the same as the Toshiba restore CD if your model has one. The restore partition is located on a separate partition on the hard disk (if it has one).
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
5. Select Recover to out-of-box state.6. Click Next again.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
2answers
Cant restore to factory settings tried 0,f1 and f8 none work
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1. Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2. Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3. Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4. Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5. Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6. Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thank you for using fixya.com
2answers
How to factory rest
  • Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
  • Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
  • Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
  • Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
  • Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
  • Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
The hard disk drive restore utility is saved on a separate partition on the Toshiba laptop's hard drive. If that partition has been formatted you won't be able to use the restore utility. If you don't have the operating system recovery disc and the partition has been formatted, you will need to contact Toshiba's customer support to have them send you a new disc.
All of your existing data will be permanently removed from the hard drive when the factory restore process has finished running.
Reboot back to factory settings
Hi there
You can only perform a restore if the PC came with a recovery partition or recovery CD's.
Recovering the system without using Windows
  1. Disconnect all peripherals and internal non preinstalled devices from the PC, except the monitor, keyboard, and mouse.
  2. Turn on the computer.
  3. When the initial blue HP screen appears, press the F10 key repeatedly until a recovery menu appears. The progress indicator that first appears does not indicate that a recovery is taking place. The progress indicator represents the time before the recovery process is started.
  4. When the Recovery screen appears, click Next, and then click Yes to perform a normal, non-destructive recovery.
  5. To perform a destructive recovery, click Advanced, and then click Yes.
  6. After the System Recovery is complete, and the computer starts successfully, update the computer software
Post back if this does NOT work
Good luck and thanks for using Fixya!!
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
