Question about Vacuums
Timex T303T Atomic Time Clock Radio With Dual Alarm Manual
5 Suggested Answers
SOURCE: I have a Barolo AU9
use the + button to scroll to 1, 2, or no alarms (off).
Posted on Nov 27, 2010
  • 383 Answers
SOURCE: hi! I have a problem
You have tried re-setting it, Right?
What happened when you did?
Note: This problem ended up under Vacuum cleaners-
You might want to try re-listing it again-- under Electronics?-
Mack B
Posted on Jan 26, 2011
wentlanv
  • 710 Answers
SOURCE: I purchased a Timex T308S
He,
Here is a webpage with the pdf document: http://www.timexaudio.com/pdf/T308_IB57357_15.pdf
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Posted on Apr 02, 2011
  • 273 Answers
SOURCE: I have Westclox Atomic Clock,
Greetings.
According to the product manual, press the 'ALARM ON/OFF' button on the back of the clock until the bell symbol and 'Zz' disappear from the display screen. These symbols are between the hour and minute digiits, above the colon ( : ).
If you would like to see the instructions, they are in .jpg format:
Front page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%201.jpg
Back page of instructions:
http://www.poyntsource.com/New/Pathimages/westclox%2070026%20-%20page%202.jpg
You might want to save these images on your computer in case the webpage is no longer available.
Good luck from Detroit, MI.
Posted on Jun 12, 2011
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
I have Westclox Atomic Clock, Model # 70026. I have lost the instructional manual. I only activate the alarm for 6:00 AM on Sunday, then I silence the alarm by pressing the Alarm on/off button. But...
Greetings.
Jun 12, 2011 | Vacuums
I have just purchased a second hand AWA CRD176X CD Clock radio that did not come with a manual and I am having trouble setting the time, alarm time etc. Can you please help out at all. Thanks in...
Hi Chris, is this the one?
Like most of this type, it should have a button named TIME, and another one named ALARM.
Then there should be one button named HOUR, and another one named MINUTE.
With the radio turned off, press and hold the TIME button, then tap the HOUR button until you reach the current hour, AM or PM.
Release the TIME button.
Press and hold the TIME button again, and tap the MINUTE button until you see the correct minutes.
Now repeat the same operation with the ALARM button, to set the time the buzzer or music should come on.
If you have any further questions please email me.
Subject: AWA CRD176X CD Clock radio
faxmando@yahoo.com
I can't make out the names of the buttons or functions from my image, so if you need any extra information, please send me a clear image of the top and front of the radio.
Thanks!
Jerry
May 30, 2011 | Vacuums
I purchased a Timex T308S Nature Sounds Dual Alarm secondhand and need an owner's manual so that I can figure out how to operate it.
He,
Handie Andie
Apr 02, 2011 | Vacuums
I have an older model rca cd clock radio dual alarms. I cannot find my instructions for setting the clocks time. The batteries were dead when the electricity went off. Now the time keeps flashing the time.
For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
There are manuals for several RCA cd clock radios available from their site: http://support.rcaaudiovideo.com/select.aspx?u=manual . Check if your specific model is listed in the menus.
I hope this helps.
Feb 03, 2011 | Vacuums
I have a Sio/Scan Atomic Clock that gives time, indoor and outdoor temp. I have lost the instruction manuel and cannot set time or date since I changed batteries. CN5 V00 U Can you help me?
The Sio/Scan Atomic clocks should automatically set the time and date.
Place the clock in a window facing towards Colorado and give it 24 hrs to update
If that fails here's the web site for them:
http://www.skyscaninfo.com/content/manuals.html
Jan 03, 2011 | Vacuums
Vacuums Logo
133 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
