Question about Mitsubishi VS-50501 50" Rear Projection Television
Big screen TV
I have a big screen TV that has double vision. The repair man said it was not the convergeance. What is causing the double vision then?
  • Anonymous Jun 02, 2008
    I just found your informative site here. I have a Mits. 50" proj. TV which is only about 6 1/2 years old. I have those double images which the other person described, and some of the colors are showing up like crossed over and slanted. Can you please give a ball park idea on what a repair may cost me. I'm thinking it may also be this "convergance" problem but I dont know too much about that. Thank you very much
    Dave
    e-mail Rave910@aol.com
  • 121 Answers
Chances are the repair man wanted to sell you a whole board because with mitsubishis this problem is amost always the convergence ic's also in that model very seldom the resistors burn out in that unit its almost always the IC's that do that. I looked for you information you have an old chassis but I think its similar to the Vz2 I believe you need IC number STK391-020 thats based on theVz2 chassis but pls double check and you need 2 of them you can also save yourself if you know how to solder a lot of money by replacing them yourself its about a 45min job if I can help you any further pls let me know or if you would like a link where you can buy your parts very reasonable with tech online support let me know
Posted on May 08, 2008
I have an rca 60 inch big screen..it just happen to show double vision looks 3d with out the glasses..lol ....sound is all good just the picture..model number..mm61110 chassis number..mmc102g..i love...
Yes it can be fix, first try to adjust the convergence setting in the setting menu then go to convergence section, adjust the red and blue convergence. You should be able to move the red and the blue convergence up, down and left, right but if you cannot move this far enough the convergence IC is defective and should be replaced. This convergence IC is attached to a large aluminum plate, this is the heat sink and the convergence IC has a marking of STK-#### followed by a number, in order to replace this IC you should have a soldering iron, desoldering pump, soldering lead be careful when pulling out the IC you may accidentally tampered or damage the PCB and caused much damage to the unit. Note before opening the back cover of your tv be sure to unplug it first. But if you are not familiar with electronic parts you can contact a service technician to do it for you and save you from stress good day and best regards.
Aug 30, 2011 | RCA D52W23 52" HDTV CRT TV
Turned the tv on and the bottom left looks like a turning page, picture is also blurred and words are double-vision. can this be repaired
TV needs convergence output ICs replacement as existing got defective and causing above said symptoms. These are two big black ICs on D board of tv that will be replaced.
Let me know if you have additional question.
Thanks.
Jun 21, 2010 | Sony KP-57XBR10 57" Rear Projection...
2nd time--i have a phillips projection tv, can't read all of mod. #5----63h/17.( measures 55 inches diag.) 2004 nov.,dptv335, 347h, e 10839 receiver, no man. 2nd owner. My problem is the tv has a double...
Thats caused by failed convergence ICs your model uses two STK392-120 ICs and 12 resistors 6.8 ohm 1watt. You can get the DPTV305-345 convergence repair kit which comes with instructions from www.tvrepairworld.com
Apr 01, 2010 | Televison & Video
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 29, 2010 | Toshiba TZ50V61 50" Rear Projection...
53inch RCA big screen tv , double vision...you asked me Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if...
Just press menu and then scroll down to settings and then under settings menu you should be able to see convergence. If not its disappaeared and thats a easy an inexspensive repair.
Jun 14, 2009 | RCA D52W23 52" HDTV CRT TV
I have a 53inch RCA big screen tv, we have double vision
Is the convergence adjustment option still listed on the on screen menu or has it disappeared? Thats a very easy chassis to repair so let me know if the option has disappeared or not and I can asssist you with how to fix it.
Samsung tv #hcm5525w is on but has double vision
The problem sounds like it is the convergence output ic's are bad. I would let a repair man fix it.
Nov 14, 2008 | Samsung HCM5525W 55" Rear Projection...
Double vision on my Mitsubishi 46 inch width screen--TV is 5 years old
any repair shop can re converge the tv for you.id do some calling arond and get a few quotes to see what it would cost to have them come to you
Oct 09, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Phillips 60" projection TV Double vision
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can repair this yourself. Let me know if you wish to repair this and I can provide you with additional details.
Dan
Aug 08, 2008 | Philips 60P8341 60" Rear Projection...
Televison & Video Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
