Hard drive boot
I cannot boot to my hard drive. The bios does not detect my hard drive, yet it appears in device manager and I can access the hard drive via the F8 key and selecting start normally. What could be the problem and do you have a possible solution?
  • 61 Answers
What do you mean by "it appears in device manager " if you cant boot there is no device manager. That aside it sounds like you are putting in to big of a drive for your BIOS so go to the motherboad,s web site and download the lastest BIOS
Posted on May 08, 2008
    Genius:
  • 3,587 Answers
If you can't see the hd in bios, it's not really there..right? you can turn it off, in set up, restart, then enter setup again, and turn it on..make sure it's seated firmly in that section, yes?
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Boot device not found, insert a boot disk and press any key
The "no bootable devices found" error can create headaches, as well as occasional heartache if you're a laptop user. This error appears when your computer is unable to find a device or file required for normal operation. It could indicate one of three issues: hard drive failure, software error or motherboard malfunction. Any of these potential problems can render your laptop useless. Hard drive failure or software errors can lead to data loss, which can cause anguish and catastrophe, depending on the files business information, family photos, student projects at risk.
Hard Drive Failure
The interior of a hard drive is akin to a turntable. Most hard drives contain two to three discs, known as platters, which are similar to records. These platters are read and written on by a tiny needle called the read/write head, similar to the arm and needle on a turntable. When a hard drive functions properly, the platters spin and the read/write head accesses the files necessary to boot your computer. Improper function of any of these physical pieces can cause a mechanical failure and result in the "no bootable devices" error. Software Error
In rare instances, a software problem more specifically, a particularly nasty virus may cause the "no bootable devices" error.
Most often, if a virus attacks and corrupts your system, your computer can still detect the hard drive and operating system, and you'll see some attempt at a normal boot.
If a virus attacks certain system and startup files, however, they may not be detectable next time you boot your computer, thus causing you to see "no bootable devices."
This may also happen if you are manually deleting files from your computer and accidentally delete system files.
Motherboard
Sometimes individual components of your laptop's motherboard malfunction, which can cause problems ranging from loss of wireless capabilities to inability to detect an external power source.
If the components that detect your hard drive fail, your laptop is unable to receive signals from the hard drive and therefore may display the "no bootable devices" error.
Repair
Fixing a "no bootable devices" error can prove costly.
If motherboard failure caused the error, you're probably better off purchasing a new laptop; unless it's under warranty; the average motherboard replacement costs $250 to $500.
You can reinstall your operating system to resolve software errors, which is fairly inexpensive by computer repair standards, costing $80 to $130 dollars, but this step may also overwrite your existing data.
In some cases, data may prove so badly corrupted it's not salvageable.
If you can recover it, however, that raises your repair costs. additional fee.
If hard drive failure caused your "no bootable devices" error, you can replace the drive.
If you need to recover data from a malfunctioning hard drive, send it to a clean room for recovery.
In a clean room, technicians disassemble your hard drive and image each platter; this kind of data recovery is extremely expensive, costing up to $2000 depending on the work involved.
Prevention
There is no way to guarantee you will never receive a "no bootable devices" error, but there are some steps you can take to help prevent it from happening.
Keep your laptop on a flat surface when using it, and avoid any bumps that may cause the hard drive's read/write mechanism to lock up.
Avoid transporting your laptop while the hard drive is active; turn your computer off while traveling.
Additionally, regularly run an anti-malware program to catch and remove viruses or spyware before they cause system problems.
http://www.upgradenrepair.com/Issues/N/nobootabledevicefound.htm
also you might
HP laptop no bootable devices found
Turn on your HP laptop with Windows Vista or Windows 7 and press the "Esc" key repeatedly to access the startup Menu. Press "F10" to access the BIOS.
Press "F9" to restore the BIOS to its default settings. Press "Enter" to verify that you want to restore the BIOS default settings.
Press "F10" to save your changes and exit the BIOS. Press "Enter" to confirm that you want to save the BIOS changes and continue booting up the laptop.
HP Hard Disk Test
Hold the Power button down for 15 seconds when the laptop is turned on to turn off the laptop.
Press the Power button again to turn on the laptop and press the "Esc" key repeatedly to access the startup Menu.
Press "F2" to access the System Diagnostics.
Click "Hard Disk Test" to begin testing the hard drive.
If "Pass" is displayed after all of the tests then the program fixed the error.
If "Fail" is displayed after any of the tests, proceed to Section 3 if you are using Windows Vista and Section 4 if you are using Windows 7.
Recover Windows Vista Factory Settings
Click "Start," "All Programs," "Recovery Manager" and "Recovery Manager" again to open the HP Recovery Manager.
Click "Advanced Options," then click "System Recovery" and "Next."
The laptop will restart and will boot up to the HP Recovery Manager.
Click "System Recovery" and click "Next."
Click "No" when asked if you want to use Microsoft System Restore and click "Next."
Select "Recover without backing up your files" and click "Next."
Click "Next" to begin the recovery process.
When the process is finished the laptop will restart and boot to the Windows Vista setup screen.
Recover Windows 7 Factory Settings
Click "System Recovery."
The laptop will restart and will boot to HP Recovery Manager. Click "System Recovery," then click "Next."
Click "Recover without backing up your files" and click "Next."
When the process is finished the laptop will restart and boot to the Windows 7 setup screen.
Jun 26, 2013 | Acer Aspire One PC Notebook
When I turn on my lab top the windows boot manager comes up
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 23, 2013 | Acer Aspire 5810T-8060 Notebook
Tried to boot from USD, CD/DVD Drive but failed. Still showing No bootable device -- insert boot disk and press any key
To boot up from the DVD drive go into the BIOS setting - boot device order and move the DVD as the first boot device and the hard disk as the 2nd boot device.
If you want to boot up with the USB then move the USB as the first device. If the USB is not listed as a boot device then it is not possible to boot up with an USB device.
May 26, 2012 | Acer Aspire 4930-6862 Laptop
IBM Lenovo T400 missing boot manager at start up
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 11, 2012 | IBM ThinkPad Computers & Internet
Check cable connection..! PXE-E63: Error while initializing the NIC PXE-MOF: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key
Hard drive is not detected. Change the Boot sequence in BIOS
1. To access the BIOS you must tap F2 or delete key upon turning the computer on
2. Try to look for the Hard drive if it is detected by BIOS if not got to step 6
3. Look for Boot Sequence or anything that is associated Boot
4. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
5. Save the changes and Restart
6. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
7. If Step 6 did not work I think you need to replace the Hard drive
Thanks for Choosing
Jun 16, 2011 | Acer Computers & Internet
Hard drive status: faild model: WDC WD2500JS-22NCB1 is there a way to check this drive
You can open the device manager and see if it says "this device is operating correctly" ...go to start, right click computer, Manage, and then on the lh side click device manager. You can also go into setup when your computer is booting (this is your bios) and see if there are hardware tests in there...many bios's have a hard drive test in there. But, if you got an error that says your hard drive failed...your hard drive is more than likely crashing if it's not gone yet, I would back it up. Usually they get a SMART failure before they are actually gone. Yes, the detection programs now detect certain hard drive failures, and can detect a failing hard drive before it's all the way gone...this is very helpful because it gives you time to save your data.
Jan 13, 2010 | Gateway Computers & Internet
Not detecting hard drive
Need to know what operating system you are using. Win XP should see the external (I'm assuming it's a USB drive). Are you sure the USB port is working? Try another.
You may have to right-click on My Computer, and choose Manage from the menu. Go to disk management to see if the computer sees the device (probably Disk 1 for you). You may have to enable it.
Mar 11, 2009 | Compaq Presario 3045US Notebook
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Feb 17, 2009 | Acer Computers & Internet
Urgent : 2.5" Seagate External HardDisk USB2.0 Problem
hi there have you tried to boot to bios and selecting the device from there and save and reboot and see what happnes
Dec 29, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
