I have dimmer switch controlled ceiling fan. What happens is the dimmer switch seems to works for a few weeks. Then it doesn't behave like a dimmer, but only as a switch - meaning that the fan gets on only at the maximum position of the dimmer. If dimmer is even slightly lowered from the maximum position, the fan gets off. This happened to a previous dimmer also and I have changed to a new one - but still same problem. What could be the cause?
  • 17,130 Answers
It is better to switch over to the stepped switch type dimmer as the potentiometer( the control ) in these types wear off very easily.
So when the carbon track loses contact the varation of the resistance to feed the SCR does not happen but happens only att the contact point which is at the end.
So replace the potentiometer with the same type higher power rating or replace regulator with the STEPPED TYPE... which is also noise free.
Posted on Aug 30, 2010
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
Hunterfan com
If you have a remote then you can't use the dimmer switch on the wall. Put in an on/off switch.
Sep 20, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a dimmer switch installed and it wont work with the celing fan
Your question has two switches and 1 dimmer.
The fan switch works.
The light switch works.
The dimmer does not. What is the dimmer connected to?
Dimmers typically will not control fan speed unless they are rated to do that.
Do you have a 3-way switching where two switches control same light, and you installed the dimmer in place of 3-way switch?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 06, 2012 | Westinghouse Contempra Trio 42" Ceiling...
I cannot get the light to turn off on my Hampton Bay fan. Everytime I turn the fan on the light also automatically turns on. The remote appears to be useless, everytime I hit the light/dimmer button...
Possible that the logic control within the fan unit is defective if is seems to switch on both. For a start you can try to clean the remote pads to confirm if the pads are accidentally contacting when pressed for one function. If dimmer works then the selection mode could be the culprit.
Jul 04, 2012 | Hampton Bay YG092-VPW 52'' Preston Vintage...
My remote stopped working for my fan.On the front of the remote it reads that that6 any wall controls hooked in conjuction with this remote control will permanently damage remote. My electrian disconected...
If you had a dimmer switch in conjunction with the fan you probably did burn it up. You have to have motor controls that are compatible. It does take a few days to burn it up. More details please.
Nov 05, 2010 | Universal Remote Control Hampton Bay...
Trying to install lsdc163pwv for ceiling light operated by 2 different switches. Install box is through switch with black common hot wire, red and black travelers and 2 white neutrals and grounds . New...
Found a .pdf file that shows LSDC163pwv ... it does not show wiring for LSDC. It shows wiring for other 3-way dimmers & separate wiring for 3-way fan control. This is a clue.
The Pass and Seymour download page does not load, so I can't see specific manual.
Let me provide what I know:
-Instructions might be confusing because LSDC works for both single-pole and 3-way circuits ... which probably adds a lot of extra wording in manual
-LSDC Device has single-pole/3-way dimmer (this requires 3 wires)
-Device has single-pole/3-way fan control with 3 speeds (which requires 3 wires)
-That's 6 total wires
-If I understand correctly, you just want to control a ceiling light? -And you do not have a fan? And your ceiling light is set up with 3-way switches.
-IF you are also wanting to control a fan in addition to the light, the box will need separate wires that go specifically to the fan >> your description shows that you do not have separate wires for the fan. Is this correct?
-Without separate wires to the fan, you can still control the light ... but if wires to light also turn the fan on-and-off, then the LSDC is not the right control since a dimmer for lights will not work on both fan and light.
To wire the light:
-You have identified black common wire for light (it is connected to dark-colored screw on 3-way switch)
-You have identified travelers that connect the 3-way switches
-The neutral wires seem to be twisted together at back of box.
-I think the dimmer is located on the top, and fan control is bottom?? Not 100% sure >>>
-Question: are there 3 wires that are associated with dimmer?
-If you can see 3 wires for dimmer, one of those wires should be black ... just hook that to common, and hook other 2 wires to travelers ... and see if it works. If not, keep connecting them until correct combination is found.
Tip- I read a lot of electrical part manuals, and when confused, I write out the instructions so it breaks down the information.
Oct 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
My dimmer is not working
Never use the dimmer switch for ceiling fan.
Jul 19, 2010 | Hampton Bay 24002 Ceiling Fan
Dual-switch controller was installed by electrician 1 - 2 yrs ago, working fine (controlling ceiling fan with lamp). This week, spontaneously, green indicator lights on lamp (top switch) cycle up and down,...
Sounds like it needs to be repgramed, but it may not be in the switch, maybe in the lamp/fan receiver (sounds like the wireless one), if this is the wired version, you may have to check all connections to make sure they didn't come loose.
Jun 25, 2010 | Lutron Maestro MultiLocation Fan Control...
Ceiling fan is controlled by dimmer
Yes, if the hot wire going up to the fan is coming off the dimmer, it is reduced voltage and will slow down. There maybe a separate hot from another switch??
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 26, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Remote wont' work after changing battery
Seem like you have a bad lectronic control circuit in that fan.
Jun 29, 2009 | Oasis Hunter 54' Ceiling Fan
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
