Question about Canon S 750 InkJet Printer
Can't print Green and orange light flash alternately. Have unplugged, checked drivers. Is the printer just worn out. It is 7 years old. The last few times it printed it made very loud noises and has red stripes running through the printed sheets.
  • Jane Doe May 11, 2010
    How many times does it flash orange before flashing green? Or does it just alternate with no specific sequence of numbers?
    The sequence may indicate something like a print head problem or a larger service problem.
It flashes orange for a few seconds, and then back to green, and then back to orange every few seconds. I can't shut it off unless I unplug it. It also makes a horrible racket.
Posted on May 08, 2008
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Canon i350 printer won't print; alternates flashing green/orange.
    Sounds like the printer head is clogged or damaged.
    I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
    The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
    Hope this helps.
    Oct 25, 2009 | Canon Office Equipment & Supplies
    The printer flashes orange light five times, and green once
    Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    This also applies to the i550, i560, i950, i960
    Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
    MY MP160 FLASHES E AND # 3 ALTERNATELY
    How to clear Error Code Canon printers MP150 MP160
    CANNON Printers MP150/MP160 ERROR CODE
    E2-2 No paper (ASF)
    E3-3 Paper jam
    1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
    the Stop/ Reset button.
    2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
    service mode. (Waiting for menu selection)
    4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
    function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
    orange and green, starting with orange.)
    The number of the Reset
    button pressing
    LED Function Remarks
    0 time Green Power off
    1 time Orange Service pattern print
    2 times Green EEPROM print
    3 times Orange EEPROM reset
    4 times Green Waste ink counter reset See waste ink counter reset
    procedures below.
    5 times Orange Destination setting See Destination setting
    procedures below.
    6 times Green Print head deep cleaning
    11 times Orange Button / LCD checking
    12 or more times Returns to a menu selection
    Aug 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Not printing from one computer
    If the CHARGE/ERROR light is remain on orange with beep 1 times, it mean the paper is not properly set in the feed slot, just remove the paper and reload it properly.
    If the POWER light is flashing green, that mean your print job is not finish yet.
    YBC (/\)
    Dec 15, 2008 | Canon BJC 55 InkJet Printer
    BJC55 Printer not printing
    There are some possibilities due to the above phenomena. Let's discuss about it:
    1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
    2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
    3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
    Hope these help.
    YBC (/\)
    Nov 01, 2008 | Canon BJC 55 InkJet Printer
    Orange light blinks 7 times then green light once and repeats,
    It indicate that your print head may defective probably cause by electrical connection, u can try to unplug the print head and clean the electrical contact part with dry paper and install it back. Make sure the contact part is fix into the holder completely.
    YBC (/\)
    Oct 07, 2008 | Canon i950 InkJet Photo Printer
    Canon S 750 InkJet Printer Logo
    233 people viewed this question
    old marine
    old marine
