Hello guys,
Please if someone can help me to solve the problem with my laptop.
After I updated the BIOS, and it was successfull updated, the keyboard was unable to use.
So I tried to shut down but didn't worked.
I turn off directly on the button, and after I tried to turn on...
I got only black screen without anything on it...
Please give me some suggestions to solve these problem..
Many thanks!
I have a problem like this but my laptop is hp compaq 6530s, i don't want to call to hp center, it will be so late for me, how to resolve this problem for hp model
please tell me, thanks.
Hello everyone, could you help me for I've got problem with Toshiba SatelliteA135-S4527, I could not partition the hard drive when I open partition magic 8 it prompt with an error that the drive letter could not be read or distinguish, please give me solutions.
Thank you,
ronaldr
Change the motherboard bios whith ok bios because u have upgrade the bios with wrong ver.
Remove external power, if any, remove the battery and leave it out for awhile. Reinsert your battery and try to restart once again and if it beeps, press F8 repeatedly until your prompted to load Safe Mode or not. Choose safe mode and see if all works fine or not. If it does the problem is related to a bios change affecting your unique video adapter. Ask Toshiba for advise.
If this doesn't help choose the below sequence.
Use the flash disk you used to flash the bios and restore the bios with the backup you made before you flashed to begin with. If you didn't make a backup, use a different PC to download the bios version most close to the one you had and flash your laptop with that version. If all is well after that, let Toshiba know what happened even if you are out of warranty. If this doesn't resolve your problem something else went wrong and seek professional service.
Tyr this, turn your computer and just use your keys to select the control panel. 2 go into devices and see if your mouse is installed if the show s that your mouse is on there. Please select the mouse to refresh it. 3 Go back to the start menu shut down the computer for 2min the turn on strike the F12 key I believe and see if your mouse is installed.
Try connecting a regular keboard to your laptop. You should have a port that will accept a mouse or keyboard. If this works then you can access your BIOS or setup page. You may have to go to Toshiba for the latest BIOS update and flash your BIOS. Let me know how you make out.
wat version of the bios update did u use
