Question about Samsung Refrigerators
Samsung RSH1DBRS twin cooling unit - following a power cut the fridge is not cooling the freezer is fine
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
This may help ">
Posted on Sep 15, 2010
How to fix the rs 2555 refrigerator is not cooling, but the freezer is fine
1) Twin Cooling System
·The refrigerator and the freezer have two
evaporators.
Given this independent system, the
freezer and the refrigerator are cooled individually as
required and are, therefore, more efficient. Food
odor from the refrigerator does not affect food in the
freezer due to separate air flow circulation.
The Evaporator unit for the fridge may need servicing.
if you handy with tools you can fix it yourself the manual link is below
http://vdmeulen.net/handleiding/Samsung%20SR-S24%20FTBS/samsung%20rs2555sl%20service%20manual.pdf
Aug 16, 2014 | Refrigerators
I have samsung french door twin cooling the refigerator is not cold enough,frezer working fine,ice maker working fine,
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Aug 19, 2011 | Refrigerators
Samsung RSH!NHSW fridge freezer Freezer fine. Fridge icing up. temperature between 8 and 10. Will not go lower. In cool place. Why?
We've just had exactly the same problem on our RSH1DBRS. After a recommendation from a friend of ours, we bought a DIY kit from Appliance DIY Repairs. It's a very simple repair, and ours is working just great. We had Comet out to it a month ago, but whatever they did never worked, and it went wrong again within a week. So it looks like the DIY idea worked!!!!!
Feb 07, 2011 | Samsung Refrigerators
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
Do the samsung twin cooling fridge freezer does it need gas??
hi . all fridge freezers need gas ? .. depends what wrong with yours .. checck out
samsung fridge freezer problems on youtube
some videos ....
and
Nov 10, 2010 | Refrigerators
Not Cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gfad
Jun 13, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Refrigerators Logo
1,358 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
