Question about Wolf Range Kitchen Ranges
All burners the spark ingniter stays on - Wolf Range Kitchen Ranges
  • Wolf Range Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Aug 31, 2010
Grill master 4 yrs old. Ingniters work,but will
When you can see the electrodes sparking but not igniting the burner this usually means one of the module plugs needs to be grounded. When that happens the strong sparking is on the module and the arc at the electrode is very weak.
Positioning is also important. Will gas come from burner and be at the spark or is the spark at the tip of the electrode 3" away? It is totally normal to make adjustments to the electrode just like setting the gap on a spark plug.
Sep 27, 2014 | Grilling
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Ingniters on rangetop keep sparking for no reason. wWhen it is turned off.
heatman101
Apr 18, 2011 | Frigidaire Ovens
Electric ingnition not working
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Nov 26, 2010 | Magic Chef 31000 Gas Kitchen Range
How do you replace the ignition module on stove.
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Ignition problems
It sounds like the round burner orifices are dirty. Remove the round orifices and clean in warm soapy water, using a plastic scrubber or toothbrush to remove and dirt and residue around the sides of the burner. Do the same on the little electrode that protrudes at some position around the burner orifice seat.
The system works by the spark ignition module knowing a gas knob is open, and sensing for a flame by ionization within the exhaust gases of the flame. If things are dirty, then the module cannot read the ionization and shuts down the burner, and will also cause the spark to continue.
Also make sure all the burner orifices are properly seated in their holder. If not, the same thing will happen.
Jan 14, 2009 | Gaggenau 23 in. KG 260 Gas Cooktop
Pilot lights (not always) but gas will not flow into burner
First Clean the ignitor assembly and make sure the flame is reaching the flame sensor strongly.
You may need to replace the flame sensor.
Sep 19, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Burners will not light or stay lit
lhs burner - problem is probably thermo-couple. this is a safety device which prevents gas escape if flame blows out. rhs burner - you do not say if it can be lit by a match. if so then it is a problem with the electrode or the wire to it chaffed thro. if can't be lit by a match, then a problem with the gas valve which is unusual not a diy fix unless you are experienced
Apr 11, 2007 | Miele 30 in. KM320G Gas Cooktop
Some Burners Will Not Ignite
probably a worn wire to the electrode or a cracked ignitor. you are faced with taking off the hobtop and looking - no easy solution. you should not do this unless you are confident and don't interupt the gas path
Apr 06, 2007 | Dacor Preference SGM466 Gas Cooktop
Kitchen Ranges Logo
449 people viewed this question
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
Dan Webster
Dan Webster
Fred Sops
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
