My samsung cd/dvd drive wont work and i dont have the disk for it. the drive renamed it self to samsung sn-124 boot rom how do i fix the problem
  • 197 Answers
See if this will work for you, turn the computer off, open the tower and follow the cable the is pluged in to the cd drive, unplug it , wait for about 4-5 min then plug it back in, that should reset the name.www.mrhope.com/drivers/cdrom.htm here is a link also that might help too , just go the sit and find your product name and download the drivers for it
thanks
Posted on May 08, 2008
Why is my cd-rom drive saying "no media " insert disk in drive when one is already there ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 13, 2011 | Samsung SN 124 (SN-124) Internal 24x...
When i put a disc in the drive it trys to spin up but then fails and then winds down and it does that a whole bunch of times untill it just gives up. but when i go under my computer and click on the disc...
Nothing to do with the rest of the pc, it's the reading head inside the drive that is faulty: it's no longer capable of detecting the disk because it's covered in dust. Try to blow away the dust with a can of compressed air and then wipe the lens with a q-tip. If this doesn't help then the dust has been baked on the surface of the plastic lens and this is terminal - you will have to replace the drive.
Apr 19, 2011 | Samsung SN 124 (SN-124) Internal 24x...
My samsung SN-124 drive does not read discs. However, the diagnosis told me that it works normally.
Try both of these steps. They should help fix the issue.
Please press the windows key on your keyboard , hold it down, and press R
Type in devmgmt.msc and press enter
If it asks to open, click yes.
Then, you should see a list of devices installed on your computer..
Double left click the cd dvd drive choice to expand it ... Then..
right click on each listing inside the cd dvd section..
And click uninstall.
Once uninstalled. restart the computer, and test the cd drive..
It should now be working in windows normal startup!!
If not, then try the following as well.
Go to the link below.
http://support.microsoft.com/gp/cd_dvd_drive_problems
on the page that comes up. click on the green run now box.
It will start a file download ( this file is perfectly safe as its directly from microsoft)
Once you download the file, make sure to run the file..
It will run a dignostic program that will attempt to repair and fix your broken drive.
KittyTech..
Feb 21, 2011 | Samsung SN 124 (SN-124) Internal 24x...
Blanf cd not workinng
some cd drives are very fussy about what makes of discs that will work in them
Jul 07, 2010 | Samsung SN 124 (SN-124) Internal 24x...
Internal samsung cd-rom sn-124 doesnt recognize cd's/wont work
replace it. samsung cd rom even its dvd writer have lots of problems. sometime they dont want to open unless you leave a cd in it. sometime it doesnt read cd. better change it. get a Sony, LG, Pioneer DVD writer.
Aug 20, 2009 | Computers & Internet
I'd like to replace the cd-rom with a cr-rw. The unit is currently in a dell optiplex sx280 mini desktop
just open cpu cover and remove cd rom from it replaced it with your cd rw then connect power cable and ide cable to motherbord and to cd rw.
Thanks for using fixta.
Please rate solution if it helps.
Jul 27, 2009 | Samsung SN 124 (SN-124) Internal 24x...
Help please
it is necesarry software which you uninstalled... install it again...
Jul 11, 2009 | Samsung SN-124 (5501631) Plug-In Module...
Close the CD Rom tray and CPU powers off
it is broken remove it from the pc and replace
May 25, 2009 | Samsung SN 124 (SN-124) Internal 24x...
Cd drive won't work
ok if it dosen't open right heres what i did with my computer,, this is going to sound complicated but it's not. i pryed it open wit a butter knife ady pushed down on it realy heard you could hear it snap back into place,and then it worked!!!!1
Apr 03, 2009 | Samsung SN 124 (SN-124) Internal 24x...
I can frind the driver for Samsung SN 124 CD-ROM
According to this weblink =>
Drivers are only for Win95, Win98, Win98SE, DOS.
http://members.driverguide.com/driver/detail.php?driverid=11569
Dec 27, 2008 | Samsung SN 124 (SN-124) Internal 24x...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
