Question about Nokia N70 Cellular Phone
N70 no power no signal
U should try giving the phone a software upgrade b4 any thing else
Posted on May 09, 2008
Tapon mo na
Posted on Jul 19, 2008
Nokia N70 no signal problem
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 10, 2013 | Nokia N70 Cellular Phone
NOKIA N70 no network signal
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Oct 25, 2012 | Nokia N70 Cellular Phone
Nokia n70 does not show 3g icon
The 3G icon appears only when you are in 3G reception area and you are receiving 3G signal.
Ensure that you are in the 3G reception area and signal is received .some areas there may be weak signal it may also cause to select Gsm mode
May 28, 2010 | Nokia N70 Smartphone
No network
go to menu, tools, settings. next, go to network, and check that the operator selection is set to automatic. If it's not, set it to automatic, and restart your phone.
Mar 09, 2009 | Nokia N70 Cellular Phone
My nokia n70 phone weak of signal
hi im josh in cebu phils.friend may i help you? your problem is weak signal. friend when the phone is weak signal there maybe a problem in hardware of the phone. the frequency reciever is weak im sure.but you can boost its functions throught entering the setting and go to network settings and select manual search.your phone frequency will search the network connections around so the hardware will be force to boost.once it will show the network providers around you select the network you are using and it will be setted to the network in more/ higher frquencyh signal. thats all friend hope i helped you.good luck/
Feb 28, 2009 | Nokia N70 Cellular Phone
N70 no signal
try to switch it off press the call key or the one with green color key together with * and three all together then press the switch button wait it till ur logo of nokia appear but there is a risk there all ur save data would be deleted.
Sep 11, 2008 | Nokia N70 Cellular Phone
No signal
do a network settings check and see if thaht helps, if not try servicing the phone.
Feb 29, 2008 | Nokia N70 Cellular Phone
Signal
Try restarting your phone.
Move to an area where there definitely is a signal.
If that does'nt do it, try removing your sim card and reinstalling it.
Dec 30, 2007 | Nokia N70 Cellular Phone
N70 lost signal
reset your phone it might work
Nov 30, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
104 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
