Question about Acer Aspire 5610-4648 Notebook
My ethernet drive,my sound drive and my PCI drive doesn´t work.....please gave me assistance
    Novelist:
    Champion:
  • Acer Expert
  • 239 Answers
You can reinstall the sound, ehternet drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Realtek and install it and then select Ethernet and install it.
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System installed on your computer
Click Drivers
Select Audio (Realtek) and download it.
Once downloaded, install it on your computer.
Thanks and regards,
Jitha
Posted on Apr 02, 2011
Emachine doesn't recognize the ethernet cord when plugged in
Sounds like the integrated ethernet port has gone bad. You can install a new ethernet card in one of the PCI expantion slots. Then plug the ethernet into the new card, this should take care of the problem. You can not repair a bad integrated ethernet port.
Feb 20, 2012 | E-Machines eMachines Desktop PC
Can i take the old card out when installin the new d link
If you have bought a new pci Ethernet network card then yes you can, you need to completely turn off the computer and unplug from the power socket, taking the side panel off and locating your pci card, un-screw the clip that holding it in place making sure you dont touch any other part of the computer, and taking the old one out, remove the packaging from the new pci network card and pushing it into place making sure its completely down and before applying the screw to fix it in place, put the side panel back on, plug in the plugs and turning the computer back on making sure you re-place the Ethernet cable, after which on boot-up your computer will say new hardware found and install it if it doesn't do it by itself you will need to search or insert the driver cd that came with it to make sure it works perfectly. please let me know the outcome of this Kronoguy
Jul 06, 2011 | D-Link DFE-530TX+ Fast Ethernet PCI...
I have a Dell XPS400 and can not connect to the internet because the machine does not have any installed network adapters. I have always had internet access...where do I find this adapter if I can't get...
This is onr example of a Network adapter, or also know as an Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
This is Dell Support >XPS 400 desktop computer > Service Manual,
http://support.dell.com/support/edocs/systems/xps400/sm/index.htm
1) Work on a table. Computer off, and unplugged from power, open the computer case.
(Removing the Computer Cover, in the list)
2) Follow Anti-Static precautions.
[Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the delicate hardware components, inside a computer.
To relieve your body of Static, TOUCH the metal frame of the open computer case.
Should you leave your computer in the middle of working on it, upon your return be sure to Touch the metal frame again ]
3) View the motherboard inside your computer.
(The motherboard is also referred to as the Mainboard, {Proper speak}, and System Board)
Technical Overview > System Board Components,
http://support.dell.com/support/edocs/systems/xps400/sm/techov.htm#wp1053398
Viewing the illustration of the motherboard, the Ethernet Adapter Card example I gave above, would go in either one of the PCI expansion slots.
These are white in color, and in the illustration are labeled - PCI Card Connectors.
If there is already an adapter card installed in both PCI expansion slots, then see if the PCI Express x1 expansion slot is open.
In reality, PCI Express is a better technology than PCI.
Shown on the motherboard as PCI Express x1 Card Connector.
This is an example of an Ethernet Card, (Ethernet Adapter Card), that uses the PCI Express x1 expansion slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675156&CatId=200
The reason I have suggested buying, and installing an Ethernet Adapter Card is threefold.
1) You may have your Ethernet cable plugged into the Ethernet port of the computer,
http://support.dell.com/support/edocs/systems/xps400/sm/about.htm#wp1053567
[Number 3 - Network Connector],
and the built-in Ethernet is no good.
Reinstalling drivers May help, but the above is a sure thing.
2) You have an Ethernet Adapter Card plugged into one of the PCI slots, or the PCI Express x1 slot, and the Ethernet adapter card is no good.
They do go bad, and are economical to replace.
3) There was an Ethernet Adapter Card installed previously, but taken out before you received the computer.
Jul 02, 2010 | Dell XPS 400 PC Desktop
Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
Capcom´s Street Fighter IV PC doesn´t run in msi rx800xt
GPU: PCI Express x16-based graphics. Support cards include ATI RADEON X1600Pro/X1300LE or nVIDIA GeForce 7900GS/7600GS/7300GS, up to latest graphic cards (Radeon HD 3800 or Geforce 9800 series)
Jul 12, 2009 | Computers & Internet
I've replaced the hard drive & tried reinstalling XP. It said I need an ethernet adapter. The ethernet card is still in place. Is it not recognizing ethernet? What should I do?
You need to download the ethernet card driver from HP and install it. This is impossible unless you also have wire less working. If not, you'll need to go to another computer and download the driver to a disk or USB flash drive. Install that and it should work. Get the driver from www.hp.com. It will guide you to the correct driver if you have all the model number info. Good Luck.
May 03, 2009 | Computers & Internet
Ethernet card
Hello my friend thats ok.
Is just that the site i gave you, you can easily find what you are looking for from different maker and model of cards from different mnufacturer but if you cant go to this site of Dell ethernet card ok
You can use any ethernet card just depending on the slot it will go into ok
now take this site :
www.accessories.us.dell.com or
www.startech.com/category/parts/networking/network-cards/gigabit-adapters/list.aspx
MSRP st1000bt32.athumb.jpg 10/100/1000 Mbps 32 bit PCI Gigabit Ethernet Card
ID#: ST1000BT32 $29.99
ec1000bt.athumb.jpg Gigabit ExpressCard (10/100/1000 Mbps) Network Card
ID#: EC1000BT $55.99
st1000btpex.athumb.jpg PCI Express 10/100/1000Mbps Gigabit Ethernet Card
ID#: ST1000BTPEX $69.99
cb1000bt.athumb.jpg Gigabit CardBus Network Card (10/100/1000 Mbits/sec.)
ID#: CB1000BT $64.99
RATE THIS SOLUTION
ok
Oct 16, 2008 | Computers & Internet
Driver software
i am have priya's mather board of 810e
Dec 09, 2007 | Creative Labs Sound Blaster Live! 5.1...
Acer Aspire 5610-4648 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
