Question about Microsoft Xbox 360 Console
The controllers does not work, and has to be reconnected. it works only for some seconds and then asked to be reoconnected again. The second controller does not respond at all. Batteries are new and checked. What is the problem?
    Problem Solver:
  • 13 Answers
It sounds like it connects initially, then disconnects? And you said the batteries are new. Are you sitting close enough to the console? If so, then you probably have a bad controller. Borrow a controller from a friend and see if they work. If so, then you know it's your controllers. Otherwise there is something wrong with your xbox.
Posted on Aug 31, 2010
Headlamps problem
Head lights are controlled by the body control module(BCM). Since they worked for a week, I would look at the plug first for corrosion. Smae with the fuse for daytime running lights(DRL) and the relay. After that , I suspect the BCM.
Oct 08, 2014 | Chrysler Town and Country Cars & Trucks
Climate control not working on 2001 volvo
I was having the same problem with a dead climate control module after disconnecting the battery on my 2002 v70. i tried (one method that sometimes works for people) disconnecting the battery again, shorting the leads for 10 seconds, and reconnecting with the key at position 2, to no avail. I managed to get my climate control back again when I jump started the car after the battery conveniently crapped out. then i got a new battery and when i installed it the ccm died. i jumped it again, with the new battery still hooked up, and the ccm came back. it's something try.
Jan 28, 2012 | 2001 Volvo S60
My 2001 Kenmore oven error says ``E1 -F5-`` What does that mean
The E1- F5 error is a door lock error. The control has likely failed. Sometimes when you disconnect power to a range and reconnect it the electronic range control gets messed up.
You should disconnect power for 15 seconds and reconnect and see if that helps.
If it doesn't fix the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.Then turn off power again for 15 seconds and back on. Sometimes these work, but if the control has failed it won't make any difference.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Kenmore Ovens
The pump motor is on a second and off a second. The motor that drives the movement works fine. Where is the control for that? Thanks
The control for both motors is inside the pump motor itself...you will need to replace the pump motor in order to get the unit operational again. Be sure to use heat shrink insulated, self sealing but connectors when reconnecting the motor leads. Aquabot parts do not always come with them included with the new motor.
John
Jan 11, 2011 | Aquabot Turbo T
Oven gets a "fault" shortly after putting power back on.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%#TR
May 30, 2010 | Whirlpool GBD307PDS Electric Double Oven
The second controller works right upto starting the game then the hand picture seems to fade and the second remote does not work, the first remote still works
reconnect the second one the is a button where you put the battrey and on the console press both of them at the same time
Apr 08, 2010 | Nintendo Wii Console
Mercedes e320 front windows problem
Battery Disconnect Window Reset Procedure: Roll window all the way down ( in first position), then roll window all the way up. When you reach the top, press and hold the switch down for 3-5 seconds. Roll window all the way down (again), press and hold the switch down for 3-5 seconds. The window should roll up and down normally. Repeat the same steps for ALL the window switches.
Oct 03, 2009 | 1985 Mercedes-Benz 300
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Start button does not work on whirlppol range
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^&UG
Feb 15, 2009 | Whirlpool GR448LXPQ Electric Kitchen Range
Second controller doesn't recognize accelerate, reverse works
Try resynchornizing it to your Wii again. If this doesnt not work, you may have a defective Wii Remote. You should consider replacing if synchronizing it does not work.
Jan 04, 2009 | Nintendo Mario Kart (Wii) for Wii
Microsoft Xbox 360 Console Logo
16 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
