Question about Intel DG31PR Motherboard
My system is restarting after installing another 2GB dynite company RAM in another slot, with single 2GB ram it is working fine and my os is XPsp3.
    Guru:
  • 377 Answers
Just remove that ram and see the ram is that DDR or DDR1 or DDR2 if you want install the ram same as previous one and see these information i mention above
Posted on Aug 30, 2010
Maximum Supportable RAM size per slot in Dell N4010
go to crucial memory and download their memory scanner. it will tell you how much memory is installed and what the max is per slot on any computer. hope this helps
Jun 24, 2013 | Dell Inspiron N4010 Notebook
Adding more ram
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra. Welcome to Fixya, Judy Hartzell.
RAM can be increased to the maximum supported by your operating system.
Windows 32bit: maximum that it can make use of is 3.85GB of RAM.
Windows 64bit: maximum that it can make use of is Over 24GB of RAM.
Find your version including bit by checking your computer specifications. Right click on Computer/My Computer in the Start menu and click properties.
Another way is to check what is written on the Windows CD that came with your computer.
As far a mainboard limit supported is concerned, rule of thumb is 2GB per Slot. Therefore if you have two slots 2X2GB should work.
You will want to install the fastest RAM modules possible in your computer system. DDR3 1333MHz will do fine, both modules should be the same frequency.
As a note your Processor is the single core CPU from AMD, for a performance upgrade it may be better to upgrade the CPU to an AMD Athlon2 X2 250.
Take care!
Nov 25, 2011 | AMD Sempron 145, 2.8 GHz
Foxconn G31MV board problem. Have 4gb of Ram and a 2.6 Duo core, have just installed a EVGA Geforce 210 1gb into the pcie slot and WIndows wouldnt start up. It went strait to repair or start normally...
The motherboard should support 4gb of ram. Was the computer working before the installation of the video card. This motherboard has integrated graphics on it, this means when you install a new graphics card you have to enable it in the bios(and disable the integrated graphics) the instructions should have come with the card as well as the installation drivers. Normally before you pop the video card in you should setup windows and install the drivers then when they are installed you put the video card in the slot.
If you are installing the ram for the first time you should check if the system recognizes the memory be going into the bios settings and looking at system memory if not I would recommend re-installing the ram.
May 15, 2011 | Foxconn G31MV-K Motherboard
RK549AA-ABA SR2170NX problem: i think my second slot for ram is no good. i'm supposed to be able to install 2 gb max . I bought 1gb ram to install in slot # 2 but it doesn't work. can i install...
Is the 1Gb RAM you purchase the same make and speed as the original? If not, they may not be compatible with each other or the new RAM module may be faulty.
Try removing the RAM from slot 1 and insert the new 1Gb RAM module in slot and boot up your laptop to test the new 1GB RAM module.
Installing a single 2Gb RAM module should work.
Dec 29, 2010 | Computers & Internet
What is the max ram speed my pc can take
According to some research, your desktop has 4 RAM slots available. The total maximum RAM your desktop can hold is 2GB (2048MB). Furthermore, each slot can hold a maximum of 1GB (1024) but cannot exceed the 2GB total.
This means you can theoretically install 2 x 1GB RAM DIMMS in 2 RAM slots or 4 x 512MB RAM DIMMS. Both will meet the desktops 2GB limitation.
The RAM specifications for your desktop are as follows:
RAM Limit: 2GB (2048MB) RAM Slot Type: SO-DIMM RAM Type: DDR1 (not DDR2 or DDR3) RAM Speed: PC3200/DDR400 ECC Type: Non-ECC
TIP: The RAM is DDR which means that while you can install them as singles (single-channel mode), the system will see a speed benefit from installing them as matched pairs (dual-channel mode).
Aug 14, 2010 | Sony VAIO VGC-RB34G PC Desktop
Just tried running restore and now have blue screen
Compaq are a bit fussy with RAM and usually don't like mixed RAM - brand, speed, & sometimes size.
You model may not support more than 2GB, check the specs..
Try inserting a single 2Gb RAM to see if it works.
If it dosen't work and the laptop won't support more than 2Gb, you may need to install two 1Gb RAM modules.
May 20, 2009 | HP Compaq Presario C500t Notebook
Model No AL-096 Sahara memory daul channel
2 slots does NOT mean Dual Channel, that just allows for 2 RAM chips
Apr 18, 2009 | Dell Dimension 8300 PC Desktop
DG965RY board can not reboot with 'restart' button on windows Xp
Run with only two RAMS each in one of the DIMM slots. Three RAMS may not work unless supported by mobo or being exactly identical in their specs..
Nov 17, 2008 | Intel DG965RY Motherboard
Problem with Mercury PI845GVM motherboard
fine ur problem if very simple as u installed 512 mb RAM on ur pc if at possible try to connect on to the other slot and restart the computer and check ur RAM capacity in ur os if it shows as same 256mb then ur have to change ur virtual memory settings i.e memory allocated to the video so configure ur virtual memory as per requirement then free up RAM memory ..
Steps for virtual memory configuration.
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Apr 12, 2008 | Intel Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
Intel DG31PR Motherboard Logo
23 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
