SOURCE: wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
I have a micro wave national nn-v688w. now the high voltage control bc board which is gos to magnatron is useless i want to use a simple transfomer to oprate. the problem is it works for about 15-30 sec and stop the display say H87. i know i need to bild a new circut to oprate the oven so do hahe an idea.my email; raju [email protected]. thahk you
SOURCE: Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
SOURCE: Bulb blown. How do I change it?
Hello there :
first you will need to remove all of the screws off the back edges and the sides next turn over the microwave over and there will be 6 or 8 screws that are on the bottom edges remove them now turn over the microwave and using a flat tip screwdriver look at the seam and you can use the screwdriver to get the cover to start moving towards the back andd then once it is loose it will lift off
Now you will see the bulb towards the fromnt of the microwave simply replace the bulb and test it the microwave if it works reassemble the microwave and you are done ok ?
I hope this is very helpful for you
Best regards Michael
SOURCE: Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
I need to know the wiring positions for a baby belling mk1 cooker.It only powers on one hob with everything else turned off.Then the other right side hob won't heat up but the left side will but not fully.I need to know where I can get a wiring diagram or know where the wires go to all switches and components.There is 4 switches at the front,two hobbs and a grill eliment and an oven eliment I need to make certain these are all correctly connected.
CAN SOMEONE SHOW ME A FUCIN DIAGRAM FOR A BABY BELLY FOR FUCS SAKE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
CAN SOMEONE SHOW A BLOODY DIAGRAM FOR A BABY BELLING COOKER
