My stereo turns off when i turn it up then i have to unplug it and plug it back in before i can turn it back on
  • 17,130 Answers
It is possible that some errors are coming in from the input source or there is a load on the output.
SO first of all set the tone to mid point level and check. if volume gets further up then check on transcient noise on the input source.
However if there is no change then check on the speakers for loading. see if there is any impedance mismatch.
try with a diferent set of speakers to confirm.
It can also be fault in the pwoer circuit . for insufficient voltage to the power/output stage that is putting the set starved and cut off.
Posted on Aug 30, 2010
Stereo receiver turns on then shuts right.back off
It sounds like the safety circuitry is being activated to prevent a more serious hazard. The problem is most likely located in the speaker wiring plugged into the back of the unit.
If you unplug everything on the back, all of the wires going into and out of the receiver, and it still does this, then there is a big problem inside the stereo's circuitry. It may have a blown amplifier chip, and will require an electronic technician to repair it.
If it stays on with everything unplugged from the back, then if you plug each item back in, one by one, you will discover which item is the culprit.
Aug 30, 2015 | Audio Players & Recorders
Why wont the radio i installed stat in my 1997chevy cheyenne
look for a reset button to push...if this is a flip or removable faceplate type of unit ,the reset will be on the front of the stereo ..its easy enough to press with the tip of a pen...good luck
Nov 16, 2013 | Vehicle Parts & Accessories
Car stereo problems
Do you have an amp? Remote wire might have come loose and the amp is telling the speakers to stop playing. Or, you might just have a setting problem, like it\'s turned on to just the rear and the rear is set to sub. Try dinking with the settings and running flat eq....(+/- 0 on bass treb and mid). If not, then there is a master plug in the back of the system: unplug and plug back in. If none of this works, trace the speaker wires back and make sure they are connected and not melting somewhere hot.
Jun 17, 2013 | Car Audio & Video
I have the pioneer super tuner 3 DEH-1900MP. My car battery died the other day we jumped it and it is working fine but i cannot figure out how to turn back on the sterio. How to I turn it back on I've...
I have the DEH-1200MP model super tuner 3 and it would not power up after battery died and was jumped. There is a fuse at the back of the stereo that I unplugged and plugged back in and then the stereo powered up. I had already checked all of the other fuses. Took me a while to figure this out.
Jul 04, 2010 | Pioneer DEH-P690UB CD Player
Stereo turns off when headlights turned on
Sounds like you have the ground for the radio hooked up to the illumination ground wire. Check for orange or orange/black wire coming from the radio harness. Did you buy the harness for the car as well? If so then just match all the colors of wires from the car harness and the radio harness. By car harness I mean the harness that plugs into the harness that the original factory radio plugged in to.
Thanks
Mar 29, 2009 | Car Audio & Video
TV won't turn on
When I try to turn the tv on, the green light flashes and eventually goes back to red. A very faint picture came across the tv a few times but didn't stay. The tv is only 3.5 years old.
Jul 10, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
CDX changer has power but doesn't want to eject after flat battery
i resolved this myself in the end.
I unplugged the audio & power cables whilst the stereo and engine was running.
Then plugged back in.
I turned the engine off and stereo off as well.
I then unplugged audio and power again from the back of the CDX, left it unplugged for 10 minutes whilst the engine was still off.
I then plugged the leads back in and turned the engine on. the stereo recognised the CDX, but stayed on displaying "CD Checking". I switched to radio for 20 seconds, turned back to CDX and it selected CD 1 and has been good ever since.
I'm rather pleased with myself!
Steve
May 13, 2008 | Sony CDX-T69 6-Disc CD Changer
14 people viewed this question
 Grubhead
Grubhead
