Question about Car Audio & Video
Monitor dont open completly - Car Audio & Video
  • 17,130 Answers
Please check if the feed wire the flexible cord is broken or damaged. Also it can be that the mechansim link to teh drive mtorr is jammed and gets tight as it opens.
You will need to check by opening the panel for either of these issues, as the loading stops midway.
Posted on Aug 30, 2010
My lcd monitor doesnt work, power button dont work, complete black screen, its lg flatron w1952s. I bought it last year from can computers its an 19inch lcd
You should find out first if it is still under warranty. Does the same with another PC? Most failures in the LCD moniotrs are the caps in the power supply or the backlight inverter circuits, we just do not want to open it up unless we have too.
Please read below and look at the pictures also.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 29, 2010 | LG L1915S 19" LCD Monitor
Does hpl1706 monitor have speakers or I have to use external ones?
This one dont have a built in speaker so you need to use a external speaker , this is a link for the complete specs and details of this unit.....
http://reviews.cnet.com/lcd-monitors/hp-l1706/4507-3174_7-31516578.html
Jan 05, 2010 | HP L1706 17" LCD Monitor
The volume menu on my hp w2207 monitor keeps popping up and the volume on that menu auto-decreases down to 0. This does not bother me because the volume still works fin, since i dont use the monitor to...
dirty switch. I took my 2009m apart and cleaned the switches with alcohol on a qtip and the problem's gone. Not too hard to do. Leverage the case gently with a putty knife or something and it will pop open. Then pop around the edge to remove the back completely.
Dec 23, 2009 | HP 22" Widescreen Flat Panel TFT LCD HD...
Same
Hi There
If you feel comfortable to take the back off and check for loose connections or dry joints if you dont understand what im saying you may be better finding a local techie, tv repairman or radio ham to have a quick look
Regards AL
Jun 29, 2009 | Gateway HD2200 LCD Monitor
Looks like my monitors out of phase but it is not
Last night, i had a few other problems with my pc as a result of a nasty virus i got from someone on msn so i completely reinstalled vista so it is all fine now, sorry to wast any-ones time but i originally did not expect a full reinstall
Dec 26, 2008 | Ezonics EZCam III Webcam
Opening monitor
It's easy to open, just insert a flat screwdriver in each top slot and push it until it "clicks".
Complete instructions and photos at:
http://josepino.com/?open-samsung-back-cover
Good luck.
Jan 16, 2008 | Samsung SyncMaster 550S Monitor
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
Monitor problem
Sounds like you have a coincidental hardware failure. The reset button usually sets the monitor to factory default which is good in most uses. A rolling pattern on the screen is occasionally due to electronic interferrence such as a mobile phone in the vacinity. As you say your screen is fading completely suggests a hardware failure and nothing to do with your pressing the reset. If your monitor is less than 3 years old (standard screen warranty) I would contact the manufacturer and they may send you a new one.
Sep 06, 2007 | Acer AL1717 17" LCD Monitor
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
