Roland SC540 Printer
I have quite a big problem on my hands. I don't know how many of you out there are printing on these large format printers to know what i am talking about. The vinyl that I was printing on was loaded bit skew so the media pushed the media clamp on the right side of the printer further till it almost came off, where it 'tilted' and thats when the head connected it.
I can see upon close inspection tiny marks on the print head surface on all of them. I had the one replaced that looked the worse. The test print shows all the colours with maybe 1 or 2 stripes missing from each printed colour. Does that mean trouble? Do I have to end up replacing all the heads? It is ridiculously expensive. Is there a way of just replacing the 'surface' plate of the head if you understand what I mean. Please help
I have a roland fj 600 and was working fine.
two days ago when i switch it on and while showing processing on display and it will shut down with blank dispaly.
repeatly the same error ocur please help
Posted on Sep 02, 2009
OK, venter26373@gmail.com, you have it most right... However, we must look at what caused the problem in the first place. Now you addressed this when you said," take care of your printer". This is good. Before you spend money on this figure out what happened to cause this.
Make shur the media is feeding straight! Feed it out a few feet and then back again. Mark the media left and right side and watch for sideways moovement. Once you get it set straight, keep those marks and use them.
Media shift can be caused several ways. If the rollers in the back of the printer are not level with the printer the media will feed badly. This can be caused by lifting the printer using the media support arms as handles and lifting on them.
Media can also be rolled tight on one side and this can cause the media to shift as well.
The test print shows a very small rectangle for each port in the head. Maybe this is what you mean when you say one or two stripes missing? If you are missing one or two "dots" in each color, and they do not lign up in the scan, L/R direction, you can get away with it if you raise the head, and print in the low res option, while increasing the saturation. This or course will not match past jobs with the same file.
If your heads are worse... yes you will have to replace the whole head.
The use of Versaworks is only a matter of paying for the dongle "key" to allow it to work. About 1000.00$ US.
You actually have more controle with Color Rip and i quote from above,"if you use something like versaworks, you can adjust the quality only, but if you use colorip, you can set the print mode, quality, resolution etc....
So this part of the upgrade doesn't mean much. I will say VersaWorks is more frendly.
You don't switch head positions with an upgrade.
You only have to change heads when they are damaged or have outlived the time. You do not have to change switches on the mainboard.... I don't think... it's been a while.
Anyway,
there you go,
Jimmy
Posted on May 12, 2009
Hey there, i have two printers, the SC-540, and a VP-540, I love both of them, as if they were my children, the thing is you have to take care of the printer, i dont know what machine you use, but if you have read the manual they continuously refer to the heads as consumables, and that you have to replace them from time to time, now that time depends on how well you look after your machine, i have used some heads less than 6 months bofore replacing, and some kept on working for more than 2 years. it sure is expensive, but you will defenitely see the difference, a short term solution for you problem is to print on a higher resolution, of higher quality. Now that all depends on the type of rip software you use, if you use something like versaworks, you can adjust the quality only, but if you use colorip, you can set the print mode, quality, resolution etc....
a higher resolution can sort out the stripes, but you cant just replace parts of the head, you have to replace the whole head, now, if you use the sc540, you have 6 heads, if you replace them, let the techinician upgrade your machine to the sc540EX, then you can print from versaworks, which is much easier to use than colorip, but you have less tuning options. When upgrading the machine to the EX, you have to switch head positions, so it makes it worth while to replace the heads and upgrade the machine. The upgrading is not supposed to cost a lot of money as it is merely a set of switches you have to set on the main board, but while you do that, you can just as well give it a major service and then you the high cost will be worth while.
if you have any further questions, email me @
Posted on Jun 20, 2008
Pump stall hp cp1700
I know this is years old, but just in case someone else has this problem....
I just had this problem and fixed it quite easily.
Like you, my ink cartridge flooded the ink bay and caused the printer to complain about a pump stall.
Mine was fixed by taking the cover off (u don't need to) and cleaning all the ink off the white strip.
Basically, there's a white piece of plastic with a metal rectangle on it. it sites to the left of the thing under the print heads (the part doesn't move. Under the big part with all the print heads) and to the right of the paper rollers.
It's also the thing that stops the print heads from moving when they're not to be moving.
Mine was covered in black ink. I cleaned it off and turned on the printer to find it working again and no more "pump stall" messages.
I don't know what the plastic piece is for, but cleaning it fixed my problem. Also there's no "pumps" in the printer (it uses gravity to feed the ink).
Jun 22, 2012 | HP Office Equipment & Supplies
I bought a Epson Stylus NX125 and I don't know how to set the printer to print only Black & White.
You can control the format of your print-out via your Windows Printer properties (e.g. in W7: Control Panel -> Hardware and Sound -> Devices and Printers -> Printers and Faxes section -> Double click on Printer -> Pinting preferences) : under Preference/Features - 'Color Options' should set to 'Print in Grayscale'.
Sep 22, 2011 | Office Equipment & Supplies
I am an artists who wishes to enlarge pictures I take so that I can trace them onto canvas or watercolor paper. What do I need to do this? I have an hp photosmart c4680 printer. will I need a better...
I have a friend who uses this technique to start her arylics. The problem you will find is getting the images big enough. So if you were painting a 18x28 canvas you woul have to break up the photo or image up into a few pieces that would each be printed letter page size. If you have something that you can use to edit the picture then this isn't that bad to do. What I suggested to her is to take the image to a blueprint shop, print shop or other place that has a large format printer/plotter. They wil be able to print out your image to huge sizes if you want.
So yes it works and quite well, and the printer isn't as important as the quality and size of the picture if you are after details in a larger painting.
Apr 19, 2010 | HP PSC 1210 All-In-One InkJet Printer
All four colors wont print roland sp300v
you print head is dry out. Normally, it happened on Magenta and Cyan colors.
Apr 09, 2010 | Office Equipment & Supplies
Roland PC60 - flashing lights - why?
This happens occasionally with myself if I am printing a large number of labels which is taking a while and decide to cut off some already printed labels from a previous job off from the roll before the current label job has finished. It then feeds the roll back past the edge sensor on the front, gets confused and flashes the lights. I don't unfortunately know how or if the printer can be restarted from this point. If I do i'll post here or if you manage to fix it please let me know. It has something to do with me cutting the roll and the roll passing the front edge sensor.
Jan 26, 2010 | Office Equipment & Supplies
Lexxmark x8350 PDF file is to big
I would start by looking at the actual data size of the file.
Next step, I would determine is the flow control between the printer and the PC is working correctly.
If the file is very large or intensive (lots of graphic images), I would break the file into several segments.
For example, pages one to five I would highlight and then do a "Save As" and name the new file as filename1.pdf.
Once the file is saved that way, I would move to page six and do a "Save As" filename6.PDF and so on until I have broken the file into more useful segments.
If you have the file and can send it to me at don.farr@hotmail.com, I'll be happy to see if I can structure the file for you.
Don
Dec 11, 2009 | Lexmark All-in-One Printer with PictBridge
How do i disable the ink moniter on a ipf600 wide format printer
Initiate, preview & monitor jobs easily ... The Canon imagePROGRAF iPF600 24-inch large format printer produces stunning, color, ... The imagePROGRAF iPF610 features a Reactive Ink system consisting of four highly colorfast dye inks - Cyan .... The affordable solution for wide format copying, printing and scanning. ...
www.copiersplusinc.com/used.html
Dec 06, 2009 | Canon imagePROGRAF IPF600 - large-format...
HP pc 2175 problem
The paper advance is wrong.
In the left side - inside the printer there is a plastic encoder disc that should be glued to a big white gear. If it is free to move, than press it to the geas with your hand (without opening in parts the printer).
I hope this is it.
Mar 05, 2008 | HP PSC 2175 All-In-One InkJet Printer
3,733 people viewed this question
k24674
jasbo
jasbo
