Question about Bosch Dishwashers
No water is getting into my Bosch SGS55CO2 dischwasher, I've replaced the water intake hose, and checked the pump for any blockages, which is clear. What else can I do
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If you have already replaced the valve and still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
E21 code on Bosch Dischwasher...what does it mean
E21 Circulating pump blockage
This would be caused by a blockage or a poor water flow from the main motor of the dishwasher. This can be caused by a capacitor failure or for other reasons.
Dec 08, 2013 | Kenmore HE2 Plus Front Load Washer
Bosch classixx dishwasher sgs43c12 not draining.
The only way to eliminate a pump issue is to actually remove the pump and check it internally, it doesn't take much to block them and also the impellers can come loose, It sound like you are handy with tools so i suggest removing the drain pump and while it's off check the hoses that run to and from the pump for obstructions and make sure the impeller is not loose.
Mar 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
My classixx has stopped spinning and draining water.I have already checked the pump.Its clear.
If it is not draining the water, then either the pump is faulty, or there is a blockage in the outlet hose from the pump, or possibly a blockage in the hose from the drum to the pump.
Mar 24, 2010 | Bosch Classixx WVF 240S Front Load Washer...
Bosch shv56c03uc/114 Water is not draining
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Apr 06, 2009 | Bosch 24 in. SHV56C03UC Built-in...
Sink was pluged plunged and now the dischwasher will not fill it's keeping draining the water out all the time
Bosch has a safety float switch under the dishwasher basin. If water leaks into this area, the float rises and turns on the drain pump to clear out the water in the dishwasher. Hope I explained that ok :)
Anyways, usually a leak somewhere causes this and unless the leak is fixed and water is removed or evaporates, the dishwasher will remain in the drain cycle.
Feb 24, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Bosch dischwasher is not draining completely. I've taken out the mesh filter and the square plastic drain cover. Should I unbolt the white cover which I presume covers the drain? thanks!
I had the same problem, twice. Both times, the technician simply removed the drain hose and cleared it of a small food particle. Save yourself the service charge by unhooking the hose yourself, clearing it and rinsing your dishes THOROUGHLY before washing.
Feb 23, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Fluff in drum blocking pump
Hi.
You will probably have to remove the hose from the drum to the pump to clear the blockage.
access is from the rear.
Nov 23, 2008 | Bosch Classixx WVF 2402 Front Load...
Bosch wfr2460
after ensuring the sump hose and transfer hoses are clear clean out the pressure system to ensure the water wash level is not more than usual, secondly check whether the waste hose is not back filling from a sink u bend and also check the sink u bend for blockages (usually fat).
if all ok start to check the wiring connections from pump to pcb board, if these are ok then there may be a fault on the board. (pumping problems are usually easily solved with the above proceedure, the pcbs are rarely at fault for bosch but you may be the unlucky one !). tony
Aug 22, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Dischwasher will not drain
Does your dishwasher run during wash cycle? then,
Check drain hose by try this, loose the clip that hold your drain hose firmly from your dishwasher side, check carefully if no debris blocked the hose connector, water suppose to come out from that connector if it does, your drain hose was blocked with debris or mold and particles like coffee seeds etc.removed them connect the hose back run the dishwasher.
If that does not solve your problem check under your dishwasher, there's a timer activated drain solenoid that opens a drain valve to drain the wash water through a hose.
Replace it.
Jul 26, 2008 | Bosch Dishwashers
Dishwashers Logo
74 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
