Hi Yogiwiz, I really hope you can help me or refer me to someone else. The thing is I have Western Digital 120GB protable hardrive which I have been using to store stuff from pc which has no more space. Yesterday I copied some files from my work pc to my harddrive and took it home. WHen I plugged it into my home pc it recognized the drive but took a long time to open any folders and then when I looked in the folders only some of the files which should have been there were. I checked the available drive space to see if they had been deleted but no change. I safely ejected the drive and unplugged-replugged it back in. This time the USB hardware install icon popped up in the bottom right menu said my device had been installed and is ready to use but no drive? It showed USB Mass Storage Device in the pop-up safely remove menu but no drive letter or drive name. On My Computer or Explorer I also couldn't find it, just my normal internal hard drives. I tried Updating the driver in Device Manager - since the drive appears as Mass Storage Device under Universal Serial Bus Controllers and as USB Device under Disk drives - but it just said that it couldn't find a better driver than the one already installed and so did nothing even though I tried updating it under both menus already mentioned. Finally I when to My Computer and clicked Manage but it didn't even appear there so I couldn't change the drive letter if that was the problem.
I'm lost and could really use some help, I have fair bit of stuff stored on the drive (it had only 7% free space left - so maybe it is fragmentation problem but if my Windows won;t recognise the drive I can't make space and defrag it) and would really prefer not to lose it. But in a worst case scenario I'd be willing to format the drive and start from scratch but I don't know how to acccess the drive to do even that. (:<)
-   I've tried mine on two different desktop systems, and my laptop. All run 've storeWindows XP. Nothing works. Any other bright ideas out there?-   KTdid
May 15, 2008
-   my maxtor external harddrive isnt being recognized by my computor-   Guest
Hello So you don't really need to update the driver of it since its a portable drive. Did you try plugging the drive to a different usb port on your pc and if it's still not detected try connecting that driver to another pc to check if it will be detected.
Was this helpful?
Yes
No
Solution #2
posted on May 10, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Unfortunately that didn't work either, still same problem. I've tried it in both my Home and work pc (both of which run on Win XP) and in different usb ports, both front panel and rear ports, no luck.
My dell Inspiron Hard drive is malfunctioning. How do i find out ifthis is a logic error or a hard...
(More)
My dell Inspiron Hard drive is malfunctioning. How do i find out ifthis is a logic error or a hard drive crash
I have a I book G4 and i recently bought a western digital passport hard drive to back my music up!...
(More)
I have a I book G4 and i recently bought a western digital passport hard drive to back my music up! I put my entire music library on my passport to free up space on my Internal hard drive! Now i'm having a problem changing the information on my tracks! what do i need to do to fix this! Do i need to change the settings in I tunes or my passport?
Changed p.c. from vista to windows 7. hard drive will not work, any ideas how i can over come this...
(More)
Changed p.c. from vista to windows 7. hard drive will not work, any ideas how i can over come this please
My I/O Magic 320GB GIGABANK Drive has stopped working. One day I took the power cord out so I could...
(More)
My I/O Magic 320GB GIGABANK Drive has stopped working. One day I took the power cord out so I could setup my cables again and then when I plugged it in it would not turn on. I then bought a new power cord and it's on now..but now the drive isnt recongnized or anything... HELP! P.S How do I take the enclosure apart so I can put this inside my PC?
