Question about Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery
Hi, My Electrolux Double door refrigator has typical problem and no Mechanic is able to rectify it so far. One of the Technicial told that compressed has gone and he has replaced the new compressor. In freezer cooling is happening , but no ice formation and in bottom part there is very less cooling . What could be the reason.
  • Electrolux Master
  • 17,130 Answers
You have done the extreme service in replacing the compressor and still the complaint is lurking. I think the fault is not identified.The gas pressure and the new compressor pressure being order , you must see if the thermostat is working corrrect, the auto defrost is doing the timed action so that the friddge is working to the efficiency. Unless each of these are checked with the evaluation a correct fault cannot be determined than to suspect.
Posted on Aug 30, 2010
Electrolux refrig will not dispense water from door
Did you cherck to see if someone turned off the water to the unit?
Jan 12, 2015 | Electrolux EW26SS65GS
Hi, I have a double oven electrolux icon model number e30ew8cgps6. I would like to tighten the handle but only see one screw on the right side and the are three plastic covers remaining and its but the...
Thank you for your post, Karen!
Typically the door of your Electrolux Icon wall oven has a lot of layers. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the replacement part is installed correctly to prevent future issues. I hope this information helps to some degree. -Matt
Oct 19, 2014 | Electrolux ICON 30 in. Double Wall Oven
Where do you get the double sided tape to stick the glass door back on oven door?
Far as I know the glass oven door is sealed with special silicone putty that is resistant to a temperature of 300 Celsius .
Previously, the required perfect clean the surface with alcohol.
Dado
May 23, 2014 | Electrolux EOG9330 Gas Double Oven
Can i move dishwasher rack
Good Afternoon Friend, this is Z. I'm happy to assist you. Yes, you are able to move the racks on your Electrolux dishwasher by pulling them out. Depending on the model number of your dishwasher, they may be adjustable by moving them up and down. You can typically locate the serial tag, on the right side as you open the door. With this information I can double check the type of racks that are located in your dishwasher for you. Thanks!
May 13, 2014 | Electrolux Dishwashers
Door will not close
check door hook tension on door it , there is a spring controling the hook
Mar 26, 2014 | Electrolux Microwave Ovens
Can I get a replacement for the lower oven door of an Electrolux EDC6935 wall oven?
Hi Mike - I am happy to assist you. First, according to my research, the model number that you have provided me is appearing invalid according to the Electrolux database within the US. Are you located outside of the US? Generally speaking, for some units the complete door set would need to be replaced. However, may I please have the correct model number, to better address the issue at hand? Typically the serial tag is located in the storage drawer on the right side. Thank you and I look forward to your response.
Jun 18, 2013 | Electrolux Ovens
I have a refrigerator 5 years old whirlpool make double door. the problem is that its cooling efficiency is decreasing day by day and even the ice is not chilling. can u tell the reason .the mechanic...
The reason is insufficient refrigent. If I was in your place I will get the compressor changed. The refrigent will automatically be charged up. Your fridge will be as good as new and you will be free of problems for the next 5 yrs. But see your budget.
May 17, 2011 | Refrigerators
I have an Amana Refrigerator. It is a double door on top and a pull out freezer on the bottom. The freezer is working fine. The refrigerator light comes on but it is not cold and my fresh food is fading...
either the evaporator fan in the damper vent door isnt running to push cold air from the freezer up into the refrige compartment or the damper vent door between the freezer and refrige section is frozen shut and cannot open to allow cold air flow,you need to access the evaporartor coil in the freezer rear wall and check both the fan and door movement
Mar 22, 2011 | Amana Refrigerators
ICE MAKER QUITS WORKING STILL AFTER BEING REPAIRED 3 TIMES SO FAR. WHAT CAN BE DONE, NOT HAPPY WOULD NOT RECOMMEND AN ELECTROLUX SIDE BY SIDE TO ANYONE.
I work in an appliance store where every Electrolux we sell has has to be replaced due to ice maker and water issues, with some customers having gone through four brand new units. We have been told by Electrolux that it is due to the water in our area and is unavoidable. My recommendation is to request a full refund from Electrolux, and if they refuse you should contact an attorney that deals with consumer protection law. In some states consumers can be awarded up to 3-4 times the amount of the cost of the product.
Feb 15, 2011 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Open Questions:
I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defros I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defrost. The top part of the freezer was heavily encased in ice (evaporate coils I think). After perusing the web for advice I removed the the front vent, the back wall and dropped the coil panel to access the fan. The fan had obviously not been working for some time cos it was covered in ice. I defrosted the whole fridge for 2 days. Turned it back on and the freezer part seems fine although v cold. The fridge seems not to be cooling again. The compressor seems to be constantly running. Current temps are fridge 12, freezer -25, ambient 16. I haven't got anything in the freezer yet. Thermostat set on 1 (1-6 setting). How is the fridge cooled? When I removed the evap panel I could not see how cold air gets to the fridge. There aren't any holes in the fridge so I am assuming the back panel should be cooled. If the thermostat is u/s would the compressor still run? Does the thermostat control any duct vv from freezer to fridge back panel? I attempted to remove some of the insulation from the fridge rear but was worried about cutting anything under it so abandoned that. Wife now giving me grief. Pse help. Andy
Mar 02, 2017 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
See all Electrolux Icon 22.6 cu. ft. Counter-Depth Questions
Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery Logo
105 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
