Question about Akai LCT2715 27 in. LCD Television
When i turn it on, the screen flashes the logo which always comes on when you turn it on but for a quarter of a second then the led goes to orange and sits their
  • 11,361 Answers
You need to do some visual inspection and voltage checking in the power supply and in the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Aug 30, 2010
  • Akai Master
  • 8,457 Answers
Unplug,replug the tv and the cable box both back about an hour later to reset both devices.The tv now should get it broscasting signal back.Not,than the Tuner board,that the board where the incomming broscasting signal wire plug in is the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
No picture on startup , continuous flashing green and orange led
Seems that way. Fact that you saw the logo on screen eliminates the inverter board.
Nov 08, 2015 | Sony XBR-52LX900 BRAVIA LX900 Series 52 3D...
Toshiba 52L7200U not picture, just toshiba logo
Those flashes are fault indications. http://electronicshelponline.blogspot.com/ Visit the site linked here to get more details. Search the site by type in the brand name of your device in the search box at the top right of the display window to get gathered all the related posts.
Nov 07, 2015 | Toshiba 55L7200U 55-Inch 1080p 3D LED HDTV
VT420M no sound or picture and turns off by itself
this sounds like a main board failure but a defective power supply can mimic some symptoms of a bad main board. I would recommend you get a diagnosis done on the set. If I was a betting man, I'd guess the main board
May 27, 2013 | Vizio Televison & Video
Vizio m470nv will not come on, logo blinks orange to white.
It may not be the caps at all, a lot of the new LED Back-Lit TV have faulty LEDs. They short and pull down the power supply, and to a novice it will seem like a bad power supply. That means that you must replace the bad LED's in that particular LED strip before you can fix the problem. Not an easy repair for a rookie.
Mar 03, 2012 | Vizio M470NV 47 in. LCD HDTV
Nokkia 5130 -screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off...
nokia 5130: when I try to turn on the phone, the screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off
Sep 22, 2011 | Nokia 5130 Cellular Phone
Battery? console has no charge when plugged into wall outlet I push power button blue LED comes on briefly , then red flashes 3 times, and the yellow LED lights up along with the health warning on the...
What color is the power light when the system shuts off?
    Red: If the power light is red, or flashing red, when the system turns off, then the system's battery needs to be charged.
    Blue: If the power light is blue when the system turns off, then there appears to be a problem with the system and it will need to be repaired.
    If the orange recharge indicator light blinks while the system is plugged in and charging, then it is likely that the battery is not installed properly.
    If you have ensured that the battery is installed properly but the orange light still blinks, check to make sure that the battery is a licensed by Nintendo. The only licensed Nintendo DSi battery will have the model number "TWL-003" (Nintendo DSi) or "UTL-003" (Nintendo DSi XL) and will display Nintendo's logo.
    Call 1-800-255-3700 if you still need help.
Jan 27, 2011 | Nintendo DSi Matte Blue Console
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
My THOMPSON TV won't turn on!!
Circuit board inside the TV was loose!!
Feb 16, 2009 | Thomson 24WK25U 24" TV
Pc wont always turn on and keyboard and mouse wont always work
Sounds like your OS has had some vital system files deleted. you may need to reinstall your OS.
Jan 28, 2009 | Compaq Presario 5000 PC Desktop
Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Oct 14, 2008 | Westinghouse SK-32H240S Television
Akai LCT2715 27 in. LCD Television Logo
56 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
