Question about Apple iPod nano
On/off button tell me i did not see - Apple iPod nano
    President:
  • Apple Master
  • 1,932 Answers
To turn on the ipod nano press any button.
To switch off the ipod press and hold play/pause button.
Make sure the hold key in put in unhold side.
Thank You
Posted on Aug 30, 2010
My brother dcp 1510 is telling an error massage "replace the toner cartige"i have changed toner ;try to reset but i cant please tell me the exact reset code and procedure .
Hi try this press menu button hit down arrow until u see info on display press OK button hit down arrow until u see reset drum on display press and hold OK button until u see reset on display press start button press-up arrow until u see the value 10 press OK button on display should read accepted press stop until the main menu appear on display.......good luck
Jun 10, 2016 | Brother Office Equipment & Supplies
Uniden6.0 how do I change frequency
Usually yes, you push a button to go on to the next frequency in the cycle. Since you declined to specify the model of your Uniden DECT 6.0 phone I'm afraid I can't tell you exactly which button to push. I can suggest that you select the model of your phone from the list beginning here to download a copy of the manual which will tell you which button.
Mar 01, 2012 | Lands Phones
I inserted a new battery to Sharp EL 6092 ,it tell me Data problem,please reset.After reset tell me reset ok?Then i press any button it tell me again Data problem. I dont understand
First press the reset button then when the display says "RESET OK ?" press the CAPS button then the button marked "2nd" (bottom left hand corner) then press Enter. Display will then say "BUSY". Reset is then complete.
Feb 21, 2011 | Sharp Office Equipment & Supplies
Xbox 360 power button light keeps flashing and disc tray does not open
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down.
it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again.
do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance
you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin
so write down 4
then hold white button down again and press open button again
it may flash 4 again
then do it again and it may flash 2 lights
then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this
4 lights flashing
2 lights flashing
1 light flashing
2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
let me know then i can assist you further ok
Oct 05, 2010 | Microsoft Xbox 360 Console
How do I set the hour, minute, date etc.
Thank you for contacting FixYa.
    Setting the Time and Date
  1. To set the time and date on your Armitron digital watch, begin by pressing the "A" button while in time-telling mode. The seconds place will begin to flash; press the "C" button to reset the seconds to "00". Press "B" to set the hour, and press the "C" button repeatedly until the desired hour is reached. Press "B" to set the minutes, pressing the "C" button until the desired minute is reached. Press the "B" button, followed by "C" to set the month, date and day of the week. When you are finished programming the time and date, press "A" to save and return to time-telling mode.
  2. Using the Chronograph
  3. To use the chronograph feature on your digital Armitron watch, press "B" while in time-telling mode to access chronograph mode. Press the "C" button to start the timing; press "C" a second time to stop the timing. To reset the chronograph, press the "A" button. Press the "B" button at any time to return to time-telling mode.
  4. Using the Split Lap Chronograph Feature
  5. To use the split lap feature on an Armitron digital watch, press the "C" button while in chronograph mode. Press the "A" button to measure splits or laps; at the end of the event, press the "C" button to stop the timing. Press "A" once to see the final split or lap time, press "A" twice to reset the chronograph to "0". Return to time-telling mode by pressing the "B" button.
  6. Setting an Alarm
  7. To set an alarm on your Armitron digital watch, press the "B" button twice to access the alarm mode. Press the "A" button and wait for the hours place to begin flashing, then press the "B" button twice. Press the "B" button, followed by the "C" button to set the hour and minute of your alarm. When you're finished, press the "A" button to save the alarm. Press the "B" button to return to time-telling mode.
  8. Using the Countdown Timer
  9. To use your Armitron digital watch as a stopwatch, begin by pressing the "B" button three times while in time-telling mode to access the countdown timer mode. Press the "A" button, followed by the "C" button to set the hour. Press the "B" button, followed by the "C" button to set the minutes and seconds. Once you've set your timer, press "A" to return to countdown timer mode. To stop the countdown timer, press the "C" button. When you are ready to reset the countdown timer, press the "A" button. To return to time-telling mode, press the "B" button.
Best regards. Jewel
Sep 03, 2010 | Armitron Digital Sport #45/6967PNK Watch
Red light stays on wont print and i know one or 2 inks are low bt it wont tell me which ones
Open the cover and pres the button which lights twice.The carriage will move and stop.There is a mark in the left side of the printer which tell empty cartridges.Keep push resume button to tell you all empty cartridges.
Oct 01, 2009 | Epson Stylus Photo R220 InkJet Printer
Screen is not working
I can't tell you what buttons to push, but i can tell you that you can't "reprint" a fax once it has printed
Apr 23, 2009 | HP 1040 Plain Paper Inkjet Fax
Lexmark x1240 All-In-One Printer Control Panel
Hi
This is the description of printer control panel
green button-START COLoUR COPY BUTTON.....place a documnet on scanner glass...press this button..u would get colur copies of the document
Black button-START BLACK COPY BUTTON.....place a documnet on scanner glass...press this button..u would get black copies of the document
white button on the left hand side-paper feed button..to load paper into the paper feed tray
white button the right...not sure:)....i guess it should be the scan button....
all the best
Apr 02, 2009 | Lexmark X1240 All-In-One InkJet Printer
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
