Question about Canon NP 6050 Copier
Light copies i already replaced all corona wires, drum, exposure lamp, power pack, toner cartridge, cleaned all mirors but still i get light copies... i can get a better copy if i change the setting of ligth to -99 which is very high but if i change the setting even to -50 which is still very high there is no copy.... pls help....
  • globalpc_ra1 Jul 06, 2008
    i already cleaned the dustproof glass and replaced the control board but the copies are still light.. the papers are warm and the machine is using the same power as before.. when i change the setting of the potential it produces very dark copies.. what else do i need to do?
  • 18 Answers
Try turning off the potential controller. Or push the primary wires closer to the drum .5mm. Could be a potential control problem.
Posted on May 26, 2008
  • 240volts May 26, 2008
    One more thing...there is a dustproof glass that is located to the right of the charge corona and can be pulled out from the front. On old 6050s these can get filthy and cause very light copies. Pull it out and check and clean if necessary. If it's really dirty you will notice a big improvement in c.q.
    Problem Solver:
  • 16 Answers
If you have changed all you mentioned with the correct parts, I can only advice you to change the control board.
Try to warm your papers
The same power you are using now, is it the same you have been using before facing this light copy problem?
Posted on May 08, 2008
My toshiba 3560 is no print how to solution plz help me
HHmmmm. many possible causes of that sir. the Developer reach the copy limit. the corona wire is cut off. the high voltage maybe filled with toner need to clean that. or the exposure lamp is busted. Good luck in hunting Sir.
Apr 17, 2013 | Toshiba T-3560 T3560 Genuine Copier Toner...
Corona wire problem
Hi, you can clean the corona wire easy, just follow those steps:
1) Turn of printer power and unplug all cord including phone cord.
2) Make sure the scanner is closed, then lift open the top cover by its handle.
3) Remove both the drum unit and toner cartridge assembly for the color desired to be replaced.
4) With the drum unit removed, push down the GREEN lock lever to remove the toner cartridge.
5) Slide the GREEN tab left to right several times to clean the unit's primary corona wire.
6) Before installing new toner cartridge, shake it from side to side to distribute toner.
7) Remove protective cover from cartridge.
8) Insert cartridge into drum unit until it snaps in place.
9) Ensure that you are inserting the correct color toner cartridge into its proper place and then slide the drum unit into the printer.
10) Close the top of the machine and then reconnect all cords; turn on power to ensure proper installation.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
My machine says Drum Error, refer to trouble shooting for maintenance?
Drum Error:
The corona wire on the drum unit
needs to be cleaned.
Clean the corona wire on the drum unit.
(See Cleaning the corona wire on page 122.)
or
The drum unit has reached the
end of its life.
Replace the drum unit.
(See Replacing the drum unit on page 130.)
and/or
Open the front cover
press Clear/Back
Press Start, then 00
after the screen show "accepted"
close the front cover and you are good to go.
Feb 03, 2011 | Brother MFC-7340 All-In-One Laser Printer
Hi i have problem with my copier its copy page is totaly black new toner replaced but didnt use for about n year please advice thank u
It would be best for you to have the machine serviced as you have not used it for a year. the issue you have could be the main charge corona unit that sits above the drum is broken you will need to check the corona wire also check to see if the exposure lamp is coming on it could be the exposure lamp or scan harness
Feb 02, 2011 | Panasonic Office Equipment & Supplies
Why are my copies coming out solid black, even though my exposure lamp is still working?
A couple of possibilities. Basically if your exposure lamp is coming on, the light is not getting all the way to the drum that is in the toner cartridge. It could be you have a mirror out of place. When the exposure lamp comes on, the light is reflected off the original and then off a series of mirrors until it gets to the drum. If one of the mirrirs has been knocked out of place, like due to a recent cleaning then that would cause black copies. The more common cause would be the drum protection "gate" that is on top of the toner cartridge is closed and thus blocking any light from getting to the drum. You can slide out the toner cartridge and look on top. There is a gate or panel that flips open to be able to see the drum. This gate must be opened when installing the toner. Also it is possible to have a bad cartridge but that rarely causes completely black copies.
Good Luck and Thank You for using Fixya.
Dec 06, 2010 | Canon PC-920 Black and White Copier
Copies are black and where is this corona wire? I
Your cartridge has two sections, the drum and the toner section. The corona wire is on the drum section. There should be a blue tab on the top left hand side of your drum unit. Slide this tab across the cartridge one or two times, returning the tab to its original position. There should be an arrow on the blue tab that will match up with an arrow on the drum unit when the tab is in its resting position. Performing this action cleans the corona wire inside the cartridge. If this doesn't fix it you may need to purchase a new drum unit.
Dec 22, 2009 | Brother IntelliFAX 2800 Laser Fax
Changed the toner now I am getting black copies?
It's important to gently shake toner cartridge from side to side to distribute the toner. It's also important to clean the corona wire (by sliding the tab from side to side) and the drum each time you change the toner cartridge. You should remove the toner cartridge (be careful, it can be messy), clean the corona wire and drum and your copies should return to normal.
Dec 07, 2009 | Brother MFC 7420 All-In-One Laser Printer
Blank copy
the charge corona assy. is just the silver assembly that the corona wire is inside of. to help verify where your problem is, lift up your top lid and make a "sky" shot. watch your lamp under glass, and when lamp gets about 5-7" from left, quickly open front door. now, open the copier to inspect the bottom side of your drum. if you see a good coating of toner on drum, but not on paper, the problem is in the corona assembly thats on the bottom, middle of copier directly under your drum. if no toner on drum, then its very possible its the charge corona assy. on top of your drum.
hth,
razors
Apr 05, 2009 | Copystar CS-1500 Copier
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Canon NP 6050 Copier Logo
125 people viewed this question
old marine
old marine
