My Delonghi DEM10 compact dehumidifier has stopped collecting water. The unit starts and runs fine with no change in noise, but after I left it running for 3 hours in my bathroom, it had not collected any water and the air in the room still felt damp. I have checked and cleaned the air filter, but this has made no difference. Any advise gratefully received.
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Aug 31, 2010
My dem10 dehumidifier will not switch off. Micro switch foe the water tank is OK.
DeLonghi dehumidifier DEM10 repair - YouTube
? 0:52
https://www.youtube.com/watch?v=OudOYDwc-Ik
Jan 18, 2013 - Uploaded by jgphone
Here's what I found when my 5 year old DEM10 stopped extracting water ... How Does a Dehumidifier Work ...
how to mend it .com - Delonghi dem 10?
www.howtomendit.com > Cooling, Dehumidifiers
Hi I have a dem 10 my problem is when it is switched on the fan runs for a few minutes then it turns off if I turn the knob down until I hear it click off and turn the knob ... The room temperature has not altered so it cannot have stopped due to low temperature. .... If you exchange the capacitor the dehumidifier will probably work.
Broken dehumidifier - DeLonghi DEM 10? - How To Mend It
Jan 14, 2016 | Coffee Makers & Espresso Machines
Delonghi dem10 not producing water
I had this problem, so have a few people. Solved by replacing big yellow capacitor on circuit board inside. Instructions here: http://www.howtomendit.com/answers.php?id=358398
May 17, 2011 | LG DH30 GoldStar Dehumidifier
Two years old Delonghi DE400 doesn't collect water, everything looks fine and running (no water but smell in basement).
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
May 10, 2011 | DeLonghi DE400 Dehumidifier
Good morning. I have a DeLonghi DEM10 Dehumidifier. I had not used it since last winter and last week put it back on. It apperas to be functioning as normal (switching on and off), however the tank...
Are you worried as to why there is no Water in the Water Tank/Bucket at all?
Well, a few operational basics must be understood by you please.
For the unit to remove moisture from the air and draw water into the bucket/tank, the set relative humidity (%RH) must be below the current or ambient room relative humidity.
Attempt to lower or reduce the setting you have to a lower value and it should start collecting water in the tank.
Hope this helps
Nov 14, 2017 | DeLonghi Dehumidifiers
DEM 10 Delonghi Dehumidifier has Stopped collecting water but still seams to be working
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 14, 2010 | DeLonghi Dehumidifiers
My DeLonghi Portable Dehumidifier Model DEM10 has stopped working. It doesn't make the same noise when you turn it on anymore i.e the slight refridgerator sound. Does this sound like a repairable problem...
First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
Good luck.
Aug 13, 2010 | DeLonghi Dehumidifiers
I have Delonghi DE500P dehumidifier was running but doesn't pump water. how can i fix it.
Good luck
Aug 11, 2010 | DeLonghi DE500P Dehumidifier
My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Sep 03, 2009 | DeLonghi Dehumidifiers
Dem 10 Delonghi Dehumidifier not working
have you tried turning it to a higher setting ??
May 03, 2009 | Dehumidifiers
Heating & Cooling Logo
465 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
