Question about Hotpoint FFA60 Bottom Freezer Refrigerator
My fridge has become very noisy? Could you advise?
  • Hotpoint Master
  • 17,130 Answers
The fault can be the vibration of the compressor motor radiating the noise to the condenser coils. So it may be hitting against the walls of the fridge and you are getting this noise. Also tthe compressor makes tteh vibration that transmits to plastics, trays at the bottom of fridge and the rear mounting. Use good adhesive stickers to soften them.
Posted on Aug 30, 2010
Testimonial: "Thank you I will try your suggestions"
2 Suggested Answers
  • 117 Answers
SOURCE: I have a samsung side
have a look at this , or go to you tube and type in samsung fridgefreezer problems
Posted on Sep 16, 2010
GE side by side fridge and when it stops cooling it makes a loud rattle. How can I fix that. Fridge is running fine. Thanks
The initial cause is often a failure to properly level the cabinet and ensure it stands firmly on a level floor. Eventually an unlevelled compressor can become worn and prematurely noisy, wear the rubber mountings and cause pipework to become detached from clips and brackets so the usual shake or shudder as it stops becomes magnified and causes the pipework to rattle and/or the rubber mountings to be ineffective.
Feb 27, 2018 | GE Refrigerators
When we shut the fridge door a loud continuous humming noise comes from the fridge. This seems to be activated by the door light switch at the top. Thank you
There are 2 possibilities I can think of for the hum. When you activate that door switch it activates 2 fans and the compressor. There is one fan located on the compressor and one located in the vent system in the fridge. The second fan is used to circulate cool air evenly through the fridge. I would recommend holding your finger on the door switch and listen carefully whether the noise is coming from inside the back of the fridge or from the lower bottom. Lower bottom could indicate compressor cooling fan or compressor. They would need to be inspected. If it sounds more like the other fan mentioned above it would again need to be inspected. The compressor cooling fans can get stuck or become noisy due to bearing failure. The vent fan can get stuck or noisy but also in some cases if the defrost circuit is not working can chock up with ice and create a buzzing noise as the fan blades strike the ice.
Jan 13, 2017 | Refrigerators
My Fagor Innovation fridge freezer is very noisy
The condenser core is dirty is my bet and the pump is worn out.
May 24, 2016 | Fagor Refrigerators
Noisy Miele Dishwasher fan
I would lubricate the bearings with sewing machine or cycle oil.
Sep 07, 2017 | Dishwashers
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
Noisy compressor on fridge freezer
does it always make that hum noise or just when adjusting temp
Aug 18, 2012 | Kenmore Refrigerators
LG GC299BA Fridge working but noisy, freezer broken.
It sound rather like one I used to have (but worse) which was never 100% satisfactory. When it eventually failed we called in a repair man who said it had been faulty since it left the factory.
I advise you to scrap it and but a new one. If you have any similar problems with new equipment, go back to the supplier within the warranty (if you have an extended warranty, then call them out now!).
Jan 23, 2010 | LG Refrigerators
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
390 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
