LG Hdd/dvd recorder receiver system ? model lh-rh3690se, speakers ? lhs ? 36se5s, lhs36se5a, i recenty bought this player but it just keeps displaying (please wait on the dvd player), nothing shows on the tv, not even the lg logo. i have tried everything and some say it needs a code which i have no idea where to get. im is South Africa.
L have active subwoofer 4 lg LH-RH3690SE DVD REC.SO I M LOOKING 4 A PLAYER /A FULL SEAT.I LOST MAIN WHAN I SENT IT BACK 2 LG BECZ OF A TECHNICAL PROBLEM.AND IT NEVER CAME BACK.IF ANY ONE HAVE A SOLUTION CONTACT ME ON 0717016643 PLZ GUYZ HALPP ME
Posted on May 06, 2012
  • 208 Answers
SOURCE: LG RH1757 (80 GB) DVD Recorder / HDD Recorder
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Posted on Mar 18, 2010
SOURCE: Can't find a regional code to unlock the dvd player.
Insert DVD player, then switch off dvd player, press power botten (On), keep taping 0, it should now load up,
Posted on Nov 18, 2007
SOURCE: Need to play region 1 DVD in region 2
Press Setup on Remote
Scroll to lock
Press 0 (seven times slowly)
Message appears you are region free say yes
Posted on Jun 20, 2008
Hi I got a Lg HDD/Dvd Recorder Model RH1999H. Ihave a problem copying Dvd from the hardrive. When I load a completly blank disc, the recorder will not intialize the disc. How do get this recorder to intialize the disc to video. When i got to set up mode, I select Disc Format option, i cannot get into the format mode, I tried to change it but it does not change the only thing I see on the disc format mode is PBC highlighted.
Please advise
AmarE-mail nikraj@telkomsa.net
Posted on Jul 25, 2008
  • 146 Answers
SOURCE: want to know how to set my LG dvd/hdd player to multi region
IF there is a code for it you will have to check on some of the sites that have region hacks for DVD players. Not all players have the capability of changing them to region free. I looked to see if your model was listed on a couple of the sites that have directions, info and or firmware updates to change region settings on various makes and models of players, and I didn't find yours listed anywhere. It may use methods from other LG models, but you have to do a little research, some google searches and a little trial and error. Keep in mind that applying these hacks can render your unit inoperable and not recoverable. You might want to look into getting an inexpensive player from Phillips, Durabrand, Apex or one of several other manufacturers that are easy to find codes for and simple to change region coding, and in alot of cases cost less than 50 USD. Phillips are the easiest to get codes for and they are reasonably priced in most department stores like Target and Walmart or at Best Buy and Circuit City. Durabrand are Walmart brand players that cost 25 or 30 dollars and they are easy to do as well.
Hope this helps
Cheers
Posted on Jan 03, 2009
take your dvd player nearest electronis & electronic store he will gave u same matching code of your dvd payer its came prise of code is $5 to 20$
Apr 13, 2008 | Televison & Video
Cannot record t.v. programmes after the changeover on video
I put the recorder channel on AV2 and then recorded it. It worked. Thank you anyway.
Dec 29, 2009 | Samsung SV-DVD55 DVD Player / VCR Combo
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
I have LG dvd player connected to 5.1 home theatre system with 5 speakers......But only 2 speakers are working...theres no problem with home theatre, it works with all speakers when connectd to...
Please check the menu and enable 5.1 surrond option on and the dvd player dose it support surround if yes also check that u have connected the correct colour cable in correct palces..
thanks
LG Surround Sound Troubleshooting
I have a lg dvd/surruond sound and the remote suddenly stopped working. I bought a new lg riginal remote but still nothing, any thoughts?
Jan 02, 2009 | LG LH-T754 Theater System
We bought the LG HDD/DVD RECORDER MODEL RH1F99MHS with the intent of recording directly onto the hard drive. How do we make that happen?! WCSU Film Class
I got a DVD+R & a DVD-R recordable discs and I used my LG HDD\ DVD recorder model RH1F99MHS and i recorded on the discs , the DVD can read them but my pc & laptop can't also other DVD players can't play them
Apr 30, 2008 | LG Televison & Video
LH T502SH DVD Receiver System
get a rca cable (red and white) hook one end on the audio out on the back of the tv and the other end to the audio in on the back of the receiver. then go to aux crank it up!!!
Feb 06, 2008 | LG LST-3510A DVD Player/Receiver
Nov 03, 2007 | Televison & Video
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
210 people viewed this question
Top Televison & Video Experts
Electro Med Services...
