Question about Hotpoint WMA32 Front Load Washer
Hotpoint WM64 doesnt seem to be taking in enough water
Hi, My WM64 doesnt seem to be taking in enough water as there is most of the washing tablets left in the drawer. any ideas?
Cheers
  • sunneyman May 11, 2010
    Can someone help me please, I have a Hotpoint WM 64 from last week it gives prob. Works well but when you choose a prog it starts well but during last half (as it reaches the green line which i think it means rinse) it stops then i have to kind of go for an other wash to get the cloths rinse well. Anyone have any idea what is going wrong with the machine..?
    President:
  • 1,294 Answers
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
Posted on May 08, 2008
I am looking for an instruction manual for a Hotpoint Aquarius 1200 WM64 and I can not find one online to download. Can you help?
Hi.
Please click on the link below to open the owners manual for Hotpoint Aquarius 1200 VM64 in PDF format:
Hotmpoint WM64- Washing Machine
Regards.
Ginko
Sep 13, 2011 | Hotpoint Washing Machines
I have been putting my washing on a 40 wash and have been putting enough washing liquid in but my clothes just will not wash, i have felt the glass in the door but it doesnt get very hot, is my washing...
The hot water goes into the machine at a slower rate than the cold water does. Open the hot spigot (water valve) behind the washing machine all the way open, then open the cold spigot just enough to get the desired 'warm' temperature of the water going into the machine while the machine is filling. You may have to shut the door to allow water to flow. Remember that it takes a minute or so for hot water to reach the machine from hot water tank.
Dec 08, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wm64 does not spin dry
Remove the top cover of washer and check the brushes in the motor, replace them if less than 3-5 mill left.
If brushes o/k then make sure belt is on, and make sure it is draining o/k.
Aug 16, 2010 | Washing Machines
Hotpoint WM64 washing machine .have relacement interlock
The connections are as follows.
Brown green with sleeve to L.
Thin Black to N.
Red green to C.
Dec 02, 2009 | Washing Machines
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Hotpoint WF840P washing machine
the pump is blocked... at the bottom back there is a plastic cover, remove this and the pump is located on the back right hand side.
tilt washer far forward, place a bucket under to catch water and remove pipes.
once cleared, test again, if still no joy then you just need a new pump, but this part is a work horse so i would assume it is blocked with something like a baby wipe or babies sock (usual suspects)
Jun 23, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
My hotpoint wm64 is making a lot of noise on spin
Apr 25, 2008 | Washing Machines
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint WMA32 Front Load Washer Logo
153 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
