Question about Creative Labs ZEN V Plus MP3 Player
Deleting Voice Recording
I would like to delete all these voice recordings. I accidentally keep pressing that side button witht he red dot in the middle, right beneath the volume button. It records voice messages. I would really like to delete them. Can you help me out?
  • stevekimc May 09, 2008
    problems deleting files on the creative v plus
This is quite simple. Just go to Music Library and way at the bottom "Recordings" now highlight the ones you need to delete and hold either the "Play/Pause" button or the "Back" button (sorry mines been broken havent used it in a while i cant remember) and scroll down to reset. Hope this helped...
Posted on May 24, 2008
How can i delete the memos i recorded?
A.To ERASE
1st select the folder of deleting file(by pressing FOLDER button).
2nd press and hold " ERASE" button,
3rd within 10 second select the item you want to erase by rotating "PLAY/STOP SEL" wheel,
4th within 10 second press "ERASE" button. selected item is erased.
if this method will not work, then , the item is locked. To remove the lock folow below step B
B.TO UNLOCK
1st select the folder containg the item ( by pressing FOLDER button)
2nd press MODE button until " LOCK" or " UNLOCK" flashes
3rd within 10 seconds select the item by turning "PLAY/STOP SEL" wheel
4th within 10 seconds press the same " PLAY/STOP SEL ' wheel
item will unlock
then for deleting folow method A
below link is user manual
user manual panasonic RR-QR240
best of luck keep smiling
Jan 14, 2011 | Panasonic RR-QR240 Handheld Digital Voice...
I have a bb 9630 and accidentally downloaded a voice note that keeps replaying so I cant delete it. Any ideas on deleting the note
You should be able to delete from the Voice Note Recorder screen. If it keeps playing, hit Stop to get it to stop playing, then hit the BlackBerry button and choose Delete.
Did that work?
Nov 24, 2010 | RIM BlackBerry? Tour 9630 Smartphone
I an trying to use the voice recorder on my iHP-120
Press and hold button on left side with red dot (record)... You will see "stand by"...  Press the lowest button on right side (A-B) over and over until "source" is "int Mic"... when you are ready to record, press the left button w/ the red dot short and quick... recording will begin.  When youre ready to stop recording, press middle button (pic of square on it) on right side... that will stop it.
To find your recording, look in the "record" folder under "Audio"
Mar 10, 2009 | iRiver iHP-120 MP3 Player
Deleting voice recordings
all you have to do is go to all songs list....then you have to select a recording (most likely titled MEC(then some numbers) next hold the back arrow down for about three seconds and a little grey list should pop up....select delete song/recording. that's all you have to do.
Jan 23, 2009 | Creative Labs ZEN V Plus MP3 Player
I have an Olympus WS-311M but cant record after playing back file
Unfortunately that is not possible with this recorder to be able to replay a part of a recording and record over it. If you pause it will just allow you to continue from the point where the device was stopped. You might want to check out the DS-2300 or the DS-2400 model recorders as those devices have the ability to do what you are asking.
Jan 14, 2009 | Olympus WS-311M Digital Voice Recorder
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
Deleting the voice recording
Press and hold the MENU button to move to menu and select [Settings] → [System].
1 Use - or + to move to the file you want to delete and press the NAVI button.
2 Move to [Yes] and press the NAVI button.
● The selected file is deleted.
Feb 07, 2008 | Samsung YP-T8 Digital Media Player
How do you delete old recordings?
find the recording you want
press the erase button (front of the recorder(top left))
after pressing it let it go
then press it again
that recording is then gone
voila
Jan 22, 2008 | RCA RP5010 Digital Voice Recorder
I need to know how to delete folders from my RCA RP 5016A
Press the Erase button, it will start flashing, keep pressing until the flashing stops and the file will be gone.
Oct 21, 2007 | RCA RP5016 Digital Voice Recorder
Creative Labs ZEN V Plus MP3 Player Logo
121 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
