Question about Panasonic DMC-FX37 Digital Camera
Hallo, when I switch on it says "please turn
Hallo, when I switch on it says "please turn camera off & then on again" or "system error focus" I cannot use the wide/tele. When I switch off the focus does not retract. I have to put it on playback & then switch off. What can I do? Am on holiday & I cannot take any pictures. Thanks Finch
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 30, 2010
  • polo422 Jan 02, 2011
    i tried to place the camera lens down on a hard surface and then power it up and power off 10 times. Once i hear a little clic and now the camera is running well. Now the lens go faster. When focus error happend the lens go out slower.
    very thanks guy
    good job
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
My Panasonic DMC-ZS7 digital camera has a system error (Focus) problem and noticed that the lens or barrel does not zoom out all the way when switched on. Please help
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 30, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
After taken photos the image out of focus
On the front of the camera body, below the lens release button you should find a two position switch labeled "AF" & "M" This is the "Auto Focus - Manual" selector switch. Make sure the selector is set to "AF" for auto focusing.
Your lens may have a similar focus selector switch on its barrel. There are two types of switches used - depending on the lens. The first is labeled "M/A" and "M" The "M/A" position indicates it is in "Auto Focus" mode with a "Manual" focus over ride capability. You can simply twist the focus ring to change the focus to a point other than that chosen by the camera's auto focus system. The "M" position is Manual Focus mode. No focusing operations will be performed by the D80 auto focus system - focusing must be done by the photographer.
The second type has "A" & "M" positions. These represent Auto and Manual focus. The difference between this type switch and the "A/M & "M" switch is that when in "A", the camera will no allow the focus to be changed manually. There will be opposition to twisting the focus ring in the position. Forcing it will likely result in damage. The selector switch must be changed to "M" to change the focus.
If either switch is set to manual, the auto focus system will be disabled, so it is very important to have them both set to "A" or "A/M".
I hope this helps. Please rate my reply - thanks!
Jan 04, 2011 | Nikon D80 Digital Camera with 18-135mm...
Camera wont stay on
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its stuck. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. Another reason is memory card. Remove the card & try. If your card is virus infected the also the couse of this reason. So please visit the service center for repair that. Its a very common & repairable problem. Thanks
Apr 04, 2010 | Leica V-LUX 1 Digital Camera
When turning camera on lense opens then closes several times then the screene says to turn the power off and on again. Is there a fix for this?
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
Apr 02, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Panasonic DMC-FX35 error message
Sounds as if it has either received a knock, or foreign matter (grit etc) has got into the lens mechanism.
May 30, 2017 | Panasonic Lumix DMC-FX35S Digital Camera
Focus error
The zoom and focus operate on screw thread drives. 1 of these has detatched resulting in "ZOOM ERROR" and locked the camera up. Dis-assemble lens and re-attach drive.
May 25, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Panasonic DMC-FX37 Digital Camera Logo
216 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
