Question about Vizio P42HD Television
The picture keeps going in and out. The picture goes to a black screen for like 5 minutes and the the picture comes back for like 10 minutes and the cycle repeats
techman
  • 3130 Answers
SOURCE: Black screen after 5 minutes of use with Fujitsu PDS-420 plasma
Sorry to inform you my freind, but the main board has to be replaced in this beast. Could get expensive. there are no schematics and or componets listed to repair this module. Its a board level repair only. Try going to ptscorp.com, find their phone number, and see if they repair these boards. if not you will need to contact the manufacturer for replacement boards. good Luck Please do not forget to rate this thread.,
Posted on Dec 15, 2006
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
  • 8457 Answers
SOURCE: Video comes on but I lose the picture in 3-5
U still have sound,when screen go black?Than ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Posted on Mar 17, 2010
  • 8457 Answers
SOURCE: The tv was on for 2 hours and then just went to a
The tv have problems with it Tuner incomming Signal board,it have dead componnents on it board.Call for warrenty repair,it the Tuner board it dead.Or return where u purchase it,get a new tv for the replacement.
Posted on May 24, 2010
SOURCE: TV turns off on its own, have to keep turning it
We have placed a fan on TV and it has solved the problem. I guess it was over heating but for no obvious reason, other than we live in the tropics with no A/C in that room but lots of ventilation.
Posted on Jun 14, 2010
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
Picture flickers for 5-10 minutes then goes black
in the back of the t.v. there is a mother board. on the mother board ( im not sure what it is called so i will describe it)
it looks like a black tune. it has a red wire comeing out of he top going to the front of the t.v. connecting to the picture tubes. now see what happens is that tube will heat up and sometimes loose connection. what i found to be helpful is to stick a peice of cardnpard under it so it gets a good connection again. but do becarful because it is high voltage....... so if you decide to try to work on the t.v. please unplug it first.
Aug 07, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
Vw42L tv comes on withpicture for 5-10 seconds and screen goes black ,sound is still on
Most likely you either have a defective backlight inverter, bad back lamp. Based off of your model #, I'm gonna lean towards a back lamp.
May 10, 2012 | Vizio Televison & Video
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Vizio P42HD Television Logo
177 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
