Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer fills with water when i'm holding the reset switch, but that's all.
  • 45 Answers
May have a bad pressure switch
Posted on May 16, 2008
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
The water is continually running in my maytag atlantis it seems like it has lost its ability to stop the fill process at the right time.
Try unplugging the machine then plug it back .. this may reset the electronics .. if not ... call a repairman.
Jul 02, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Maytag Atlantis washing machine doesn't fill
maytag has had multiple problems with the neptune series (atlantis included) units. Test the pressure switch for function and continuity, and also make sure pressure switch tubing is free and clear of obstruction or pinching. Replace pressure switch or tubing if needed. Pressure control may be located in machine control board on some models, if this is the case and the tubing is checking good, replace the machine control, not the interface or motor control board, and then test. all should be checking ok.
Jul 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water will not drain, will not do anything.
I would check the lid switch. That is most likely the problem.
Apr 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis top-load washer won't fill with water, no power.
Not the lid switch>>>The water level switch ...unless you have forgot to turn the water on,Please Rate This !!!!
Dec 01, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Fills with water than nothing!
Most likely it's the lid switch, part number 22003804.
Remove the back of the console to gain access.
Jan 22, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
