Question about Daewoo Televison & Video
When my dvd+vcr recorder is turned on the only thing on the tv screen is a sreen which is split in half verticaly one side black & other side white model No DF-4100P/4150P/8100P/8150P what is the cuase . Thanks
  • Daewoo Master
  • 12,061 Answers
Ok, this usually happens when the test pattern is used to "Find" the channels with the TV. Check to see if this is indeed what your problem is. You need to turn it off.
On the back of the VCR, there will be TEST Switch, or the like switch, that must be OFF, Or, it maybe in the program, if not a real switch, usually is though, that switched on will cause that pattern will be displayed, as said it's used to tune the TV, onto the VCR's OUTPUT frequency. You turn that ON, find, "Tune" the TV's channel, onto the right station, and the turn it OFF and play the Tape/DVD. This is ONLY usually ON RF output. The Co-axial lead to the TV, But, If you use Component Blue, Red Green, for Video out, or Composite, Yellow only, for Video out, then this is not used.
Posted on Aug 30, 2010
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
My dvd/vcr is show double almost like a split screen. There is a bar in the middle of the screen and the screen itself is slpit into two parts. When i put up the menu screen for it i can see half of one...
on your remote you need to hi the pip button. thats picture in picture. it allows the screen to be split so you can watch two things at once, though most equpiment doesnt support this function yet so its useless.
Hope this helps. Please take a moment to rate:]
May 07, 2011 | Televison & Video
I purchased a MDR513h/f7 hdd & dvd Player/recorder for my cable TV. I can not watch one channel while recording another. Comast said I must have a dual turner and that is what I purchased (I think)....
This model has only one tuner, I'm afraid. You can only watch one channel at a time, unless you split the cable signal going into it. One side goes to the recorder, the other to the TV. Then you use the single tuner in the recorder to record and the TV's tuner to watch the other channel.
Sep 12, 2010 | Philips Magnavox DVD/VCR Dual Player
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
How do i/can i record tv to a DVD ]
If your using RCA cables (thats the red, white & yellow leads) you need run yellow RCA from the 'VIDEO (or) TV OUTPUT' at the back of your tv, to the 'VIDEO (or) TV INPUT' in the back of your DVD/VCR combo unit, & do the same with the red & white 'AUDIO' leads only run them from AUDIO OUTPUT(tv) to AUDIO INPUT(dvdrecorder). Now set the mode of the dvd recorder to TV IN or AUX IN. Now it should record whatever you see on the tv screen. But if your tv has an S VIDEO OUTPUT option, using an S VIDEO cable would be much easier & produces a better copy! Hope this helps!
Jun 19, 2009 | Symphonic WF803 DVD Player/VCR
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
Two problems at the same time: VCR plays split screen and DVD player won't ready Disks (Errrrr)
Getting a new one is about all you can do in this case. A repair for this type of problem would likely cost more than the replacement.
Sep 06, 2008 | Panasonic DMR-ES40VS DVD Recorder/VCR
Split screen with pscan warning on
I had the exact same problem and I consulted the manual. All you have to do is turn the PSCAN swtich off. It is located on the back of the dvd player. Then turn the dvd player back on and your problem should be fixed.
Jun 07, 2008 | Memorex MVD2022 DVD Player
JVC HR-XV33U DVD/VCR
Press and hold the Progressive Scan button for more than 3 seconds. It should clear right up.
Jun 15, 2007 | JVC HR-XVC33U DVD Player/VCR
Televison & Video Logo
53 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
