Question about E-Machines eMachines Desktop PC
CMOS Battery failed, how to replace it? - E-Machines eMachines Desktop PC
  • 808 Answers
Change ur CMOS by purchasing it from nearby shop
Posted on Aug 30, 2010
Cmos battery failed time
replace cmos battery with same kind but new one. Before bring the old one out, look carefully which position it has.
Oct 28, 2013 | Intel Desktop Board DG41WV Motherboard
My CMOS battery has failed and I need to replace it. No-one has been able to tell me what the battery is - where can I get one or how to replace it?
The battery is a CR2032 just google it. very cheap.
to replace it you will need to dismantle your laptop and get to your motherboard which is where the battery is.
Jan 05, 2013 | Advent Netbook
Reset cmos
Removing the CMOS battery for 15 mins will reset the CMOS.
The CMOS failure most likely is caused by a flay CMOS battery. replace the CMOS battery will fix this problem.
Oct 24, 2012 | IBM ThinkPad T41 Notebook
ASUS P5GZ-MX: Cmos Settings Wrong - Tryed New Cmos battery and setting time a date howto fix ?
It may just be that the new battery needs to be charged. I would leave it switched on for 24 hours to check. If this doesn't fix the problem, it could also be a failing BIOS chip or the charging circuit for the CMOS battery has failed. If the BIOS chip is not socketed or the cmos charging circuit has failed, you will need to replace the motherboard or find an electronics engineer to replace the failed components, this will probably be more expensive that a new board.
Jun 13, 2012 | ASUS P5GZ-MX Motherboard
Computer will not load windows OS. it will say bios rom checksum error on a compaq presario SR1365CL
This is a typical sign that the CMOS battery (the coin-shaped battery on the motherboard) has failed & needs to be replaced. After replacing the CMOS battery, you will need to boot into BIOS & save CMOS settings.
Jul 13, 2011 | Computers & Internet
Bios rom checksum error on a compaq presario SR1365CL
This is a typical sign that the CMOS battery (on the motherboard) has failed & needs to be replaced. After replacing the CMOS battery, you will need to boot into BIOS & save CMOS settings.
CMOS test failed while booting computer
Please check the small bios battery ( 3V) on the PC as the low voltage on this can cause bios issue and not set up the PC to boot.
Apr 01, 2011 | Computers & Internet
CMOS NOT SAVING IN MY MOTHERBOARD
It seems your CMOS battery has failed. You should replace it with the new one. Ask at your local shop for info about CMOS battery you need.
Jan 16, 2009 | Computers & Internet
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
1. New hardware has been recently installed.
2. Error or confliction with settings in CMOS.
3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS.
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Power Trouble
How to replace the CMOS battery. Like any battery the computer CMOS battery can fail or lose its charge.
No power or computer does not turn on. No power from the computer can be caused by any of the below possibilities. ... into the laptop you should see a power light or battery charge light.
How to replace the CMOS battery. Cause:. Like any battery the computer CMOS battery can fail or lose its charge. ... Most likely causes are bad power supply or bad motherboard.
Good Luck, Please dont for get to Vote.Thank you.
Dec 19, 2007 | Dell InspironTM 1501 Notebook
E-Machines eMachines Desktop PC Logo
67 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
