Dell 1545 battery plugged in not charging at 9%
    Problem Solver:
  • 8 Answers
I had the same problem with my dell 1526 laptop,I just updated the BIOS and now it's charging now.
If you want to extend the dell 1545 battery go
http://www.battery4us.com/dell-notebook-batteries/dell-inspiron-1545-battery.htm
Online tips and manual for dell 1545.
Posted on Nov 25, 2010
  • 2,567 Answers
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Aug 30, 2010
4 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Dell 1545 plugged in with correct adapter, but not charging.
Battery packs die after a while they are unable to hold charge this sounds like your case, you will need to replace battery pack, if you get two good years out of such you have already done well.
Posted on Nov 07, 2009
Testimonial: "Purchased Dell 23 months ago, almost to the day. Well engineered obscolesence."
  • 16 Answers
SOURCE: Purchased a new Dell Inspiron 6000 (9 cell) battery
Have a look in your power properties and see the settings.They may be set at when battery reaches 30% The computer shutsdown. You can change the settings to your own preferance.
Posted on Mar 15, 2010
  • 6 Answers
SOURCE: my dell inspiron 1545 says plugged in but not charging
its the charger if the charger is longer before trie changing the battery or if that doesnt work u have to replace the motherboard (around 155.00 GBP)
Posted on Aug 01, 2010
Plugged in, not charging
First, try another charger. Perhaps your charger isn't providing enough volts to the laptop
Feb 27, 2014 | Dell Inspiron 1545 Notebook
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
Jan 27, 2013 | Dell Inspiron 1545 Notebook
New battery wont charge in my dell inspiron 1545 where it plugs into the laptop burned out
It's probably the connection that's the problem. If the wiring is damaged, it wont likely pass a current to the battery itself. I suggest getting your laptop serviced.
Nov 04, 2012 | Dell Inspiron 1545 Notebook
Inspiron 1545 how to reset power adapter
1 Possibly the generic power supply plug has the wrong polarity.
2 Possibly the plug is not quite the right size for your PC, hence not making good contact.
Nov 25, 2011 | Dell Inspiron 1545 Notebook
My Dell Inspiron 1545 will not chargethe battery when plugged in.
I've seen that some Dells don't charge their batteries correctly when they're not also turned on.
Take notice if that's the case as it'll be inconvenient if you expect to have a full charge after leaving it plugged in, but powered down.
Additionally, those batteries do age and slowly 'go bad'. You should also consider the age of your computer/battery and think about how long you intend to keep it, as opposed to the cost of a battery replacement.
Best of luck, William
Mar 15, 2011 | Dell Inspiron 1545 Notebook
My dell inspiron 1545 says plugged in but not charging
Jul 26, 2010 | Dell Inspiron 1545 Notebook
My dell 1545 inspiron wont operate on the battery works fine on charger and battery icon shows 100% and charging but as soon as power removed laptop immediately powers down. physically measured battery...
I think that if it's 100% it should say that it's fully charged.There could be something wrong there.
My computer blinks with a red icon on the printer saying that the it's recommended the battery be replaced when the battery goes bad. It shows 100% charge as well.
I just got a 9 cell battery off of Ebay for my Acer Aspire that lasts 3 or 4 hours and is a little big, but fits the contacts and locks on.
Jul 19, 2010 | Dell Inspiron 1545 Notebook
Ac adapter problem with dell inspiron 1545
TRy to remove the battery, then power the laptop on with only the ac power adapter inserted. if it powers, then your adapter is ok, and insert battery while its on, battery charging should start. otherwise, you could be having a problem with your charging system.
Regards
Apr 19, 2010 | Dell Inspiron 1545 Notebook
Nov 07, 2009 | Dell Computers & Internet
Computers & Internet Logo
541 people viewed this question
David Payne
David Payne
