Question about Compaq Evo N1020V Notebook
Wireless connection i am trying to install wireless my computer is equipped but somehow the program isn't active i was told to get a cd from compaq, is there another way to activate the external wireless thank stephane from london
  • Anonymous Jul 04, 2008
    I have the same problem, the instalation locks up when inseting the adapter!!
Do u have a network adapter?
Posted on Jul 01, 2008
I have set up a wireless network at home uisng the DSL-G604T which I can connect to fine using laptops. For my desktop I'm told that I need a wireless adapter to connect. Which one would you recommend?...
If you are able to connect internet with your laptop and if you have a laptop then you should have to do the internet activity using laptop which will not cost you. And it will also help you to connect through laptop. For more contact me again.
Sep 11, 2011 | D-Link DSL-G604T Wireless Router
I am trying to install my actiontec gt704wg in windows t 64 bit
You should not have to install any drivers for this equipment to work. If it is wired, plug an ethernet cable from the back of your computer to the router. If it is wireless, you will have to enter the wireless key. If the GT704 is set to default settings I believe there isn't any encryption on the unit (meaning that you can connect without a key). If you still can't connect wirelessly, you'll have to plug in a cable and open your internet browser. Type 192.168.0.1 in the address bar and within the wireless settings you should see the WEP/WPA key.
May 05, 2011 | Actiontec GT704WG Wireless Router...
The defrag went out in my compaq computer, about 1 year ago. It uses windows xp. I was told that I could reinsert my windows program, and reinstall the defrag., without losing the other programs, that are...
to install a WinXP component u need the instalable WinXP CD(not the cd that came with you PC or a rescue disk)
Switch on PC, let the machine boot WinXP, after u get the Desktop, insert the WinXP CD, after the CD rom loads WinXP from CD, in the opening menu select:
"Install optional Windows Components:
in the next menue, select Accessories and Utilities (Tick the Box)
Click Next and u r done....shut down and re-start...
all the best
Jul 08, 2010 | Compaq Presario 5000 PC Desktop
Can i connect 2 a wireless network?
Actually it is an office with 2 different networks. Currently there are two wireless routers (router A connect to network A; and router B connect to network B), then router A with a server set for internet access. The two network somehow link together already, but all nodes in both networks can't see each other(cant share files thru "My Network Place"). All nodes equipe with Windows XP.
It’s help u.
And Thanks.
Mar 03, 2010 | HP 285527-001 - Compaq Presario...
Internet connection not working right compaq evo n1020v
Hello
First you will need to have the install disc for your card.Install driversoftware from cd or dvd, following directions.Once installed you should see a new hardware device has been found notification.
Next you will need to configure your card with the routers wep key or wireless security key.I am assuming wireless is activated on your router.Should see a light on the router lit under wireless,or a symbol.
1 start pc then start internet explorer.
2 Type in the top bar of ie 198.162.1.1 or 198.162.1.0 hit enter.
3 This should bring you to the routers home page.usaername=admin password=password or admin
4 Find your wireless tab or settings page looking for security area.
5 Find your wep or wireless security code,write this down.
6 Log off of router.
7 Go into network cards configuration program and put this wep code into the area provided.
8 Software may have found it automaticly, it just needs this code.
If you cant connect to router at step one use a ethernet cable from your pc to the router to log on.
Hope this helps.
Jan 23, 2010 | Compaq Evo N1020V Notebook
Can't find product key microsoft office home and student 2007
The product on your laptop is most likely an evaluation copy for you to try out the features of the program. You would need to purchase a key from Microsoft. If somehow the laptop came with the full software, the key would be on the bottom of your laptop somewhere near your Vista key. But again, the software you are currently using is a demo.
Mar 20, 2009 | Compaq Computers & Internet
Trouble getting a connection
This adapter's driver is pre-installed in Vista. That means that Vista should automatically see it and install it.
Power down your computer.
take out the D-link adapter.
Power on the PC. Once you get to the desktop, check in the control panel > device manager. It should not be there.
Then power off the PC again.
insert the adapter but in a different PCI slot.
Power on the PC and Vista should see it ans set it up.
The cd would not help you because the D-link Utility does not work in Vista.
I have read the the XP drivers alone would work, But try this first.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 15, 2008 | D-Link Air DWL 520 802.11b (DWL-520)...
Activate Wireless netwerk connection HP Compaq 6710b
have hp computer,unable to switch on wireless connection.im just a novice.HELP
Jul 08, 2008 | HP Smart Buy Notebook
Wireless software problems
try going to you device manager, check if your wireless device is there, if it is unpdate drivers and download new version of the wireless adapter from the HP website.
May 14, 2008 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
184 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
