The fan is functioning the cpu fan is also functioning but there is no more activity
  • 27,725 Answers
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Posted on Aug 30, 2010
Cpu fan does not work.
CPU fans do fail on occasion. Replacement is the only practical answer
Mar 19, 2013 | Acer Aspire 4741 4741g 4741z 4741zg 4743...
I have a vostro 200 large tower with a g33m02 motherboard. The cpu cooling fan is very loud. (not bearing loud, but it seams to try a lot harder than it needs too for what the computer is doing.) the cpu...
Check your BIOS Settings
CPU Configuration
CPU Internal Thermal Control [Auto]
Hyper Threading Function [Enabled]
Intel(R) SpeedStep(tm) Tech [Auto]
Power>Hardware Monitor
CPU Q-Fan Control [Enable]
CPU Fan Ratio [Auto]
CPU Target Temperature [60degC] (lowest setting available)
or you can replace it with Cooler Master XDream
Sep 20, 2011 | Dell Vostro 200 Desktop Computer
880GMA-E45......my cpu fan system not functioning,,,how to troubleshoot the error?..pls advice..
Try plugging the CPU fan into one of the other fan ports on the motherboard. If the fan still does not work, then the fan is bad. If it does work then the circuitry that controls the cpu fan speed is bad. You can try turning off speed control in BIOS and see if the fan works again in the cpu fan plug.
Jim
May 10, 2011 | MSI Computers & Internet
Please clear cmos if system no display after overclocking
Click the following picture to enlarge:
CPU Overheated
If the system shutdown automatically after power on system for seconds, that means the CPU protection function has been activated. When the CPU is over heated, the motherboard will shutdown automatically to avoid a damage of the CPU, and the system may not power on again.
In this case, please double check:
1. The CPU cooler surface is placed evenly with the CPU surface.
2. CPU fan is rotated normally.
3. CPU fan speed is fulfilling with the CPU speed.
After confirmed, please follow steps below to relief the CPU protection function.
1. Remove the power cord from power supply for seconds.
2. Wait for seconds.
3. Plug in the power cord and boot up the system.
Or you can:
1. Clear the CMOS data.
3. Power on the system again.
If after clearing the CMOS you still have no display, you may have damaged your motherboard, CPU, or RAM. If you need further assistance with this Motherboard, let me know.
Mar 25, 2011 | Biostar G31-M7 TE Motherboard
How do you troubleshoot the processor cooling fan-to see if it's spinning fast enough?
Go into bios and under advanced functions it will tell you CPU fan speed and CPU temperature
Sep 10, 2010 | Intel (D34223001) CPU Heatsink Fan
Intel P4 2.66GHz/512/533 is not working on MS9337C+.
#1. Does the CPU fan run if not then you may have a conductivity problem between fan and CPu. Did you use thermal paste or grease?
If fan is running follow directions below from my manual for MS9377C+ mainboard.
Go into the BIOS setup ,go to CPU setup, select proper voltage for you CPU. On Advanced setup page see if the hyperthreading function is revaeled. If so your CPU has this function. Set "Enabled " to test HT CPU function. If this doesn't work try "Disabling" the function. Good luck. I am about to attempt tp upgrade to a Prescott 3.0E which the box says this board supports. Sure hope so . Am running a 1.7 now.
umcds@sssnet.com
Apr 16, 2009 | Matsonic MS9337c Motherboard
Computer freezes
make sure your CPU fan is functioning correctly, this happens generally when the CPU is overheating due to fan problems or stoppage. If the fan is ok, and the CPU is not overheating, try a different memory, one of will work.
helpful ? if not reply and i'll give you other hints
Mar 23, 2009 | Matsonic MS9327E (MS9327E+(USB))...
USB PORT NOT FUNCTIONING
does your machine make it to the windows login screen, or does it fail before.
I think you haven't installed you CPU correctly, or maybe did not put heat sink compund evenly on the heat sink, and that causes the CPU to overheat and freeze.
Mar 23, 2009 | Mercury P4VM800M7 Motherboard
NX9119
The Laptop Shuts Down, Due the Processor Reaching It,s Heat Limitations, as set by the Bios/Motherboard Et,c. This Is A Safety function to Avoid Any Further Damage To The CPU Or Other internal Hardware. If the CPU Fan is not functioning, this is likely the cause. To Remedy this Problem, you,d look at removing the faulty fan ( Replace With New ) Or fully functioning Fan. And replacing the thermal Patch Or Paste, Between The CPU ( Processor ) And Heatsink Or Mating surface Between CPU/FAN.
I,d suggest not using the Laptop, until this has been repaired, as you will only cause more damage, which in turn. will become unrepairable. or very costly.
Mike @ Compurepair.
Feb 28, 2008 | HP Business Notebook NX9110 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
