Question about Sharp AR-5316 Advanced Digital Imager Copier
Printer message error H2. - Sharp AR-5316 Advanced Digital Imager Copier
  • 61 Answers
Fuser problem, Check to make sure fuser installed and connected. Use Sim 14 to reset. Hold the light expouser key until all lights flash and - - shows on display then enter 14 and press the copy button. Machine should restart.
Posted on Aug 30, 2010
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
H2 error message
H2 Error
Content
Thermistor open detection
Detai
l Fusing thermistor open
Cause
Thermistor defect MCU PWB defect
Fusing section connector contact failure
Power supply failure Fusing unit not installed
Check andremedy
Check the harness and the connector of the thermistor and
the MCU. Clear the self diag display with SIM 14.
Aug 29, 2012 | Sharp AR-5516s
Display error H2
Gwnerally in sharp you cancel H2 doing a reset through code 14. did you do it yet?
Dec 03, 2011 | Office Equipment & Supplies
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Code error h2
Hi
Error code H2 means fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor or due to fusing lamp. To resolve this error try and reset the unit by entering the service mode--
press # - INTERRUPT - C - INTERRUPT
then
14
start
If this resolves your issue then try restarting the printer and try the reset again. However, if reset is not helping you then you
Oct 09, 2010 | Sharp AR-5316 Advanced Digital Imager...
What is an SUC H2 Error mean on a Lexmark C500 Printer?
What is the mallfunction on a Lex 500c when SVC H2 error is displayed? thank you, johnny_key00@yahoo.com
Nov 09, 2009 | Lexmark C500n Laser Printer
Error message H2-00
H2-00 is a problem with the fuser section indicating that the Thermistor has failed.This can sometimes be reset by a service technician(Through the service menu),but may indicate that the Heater Lamp has failed.
Oct 04, 2009 | Sharp AR-M162 All-In-One Laser Printer
H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Jun 23, 2009 | Sharp AR-M205 Copier
Sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Jun 19, 2009 | Sharp AR-5320 Black and White Copier
Error message H2 or 2H
I think H" is the fuser not warming up. Suggestion trace back your replacements and make sure that all the cables are connected as sometimes when you refit the cover etc. you can knock or pull out a connection without knowingly doing it.
Thanks J
Jan 17, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Sharp AR-5316 Advanced Digital Imager Copier Logo
142 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
