Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Copier/Scanner All pages are black. there is no more light as work is copied or scanned. Direct printing is ok. I think "light bulb" needs to be replaced. If I'm right , where do I get replacement and how do I open up machine?
  • John Holland May 11, 2008
    even if Lexmark doesn't sell part, somebody must have manufactured it somewhere and there must be something compatible. How can i find part number? jmh133
  • 3,037 Answers
The scanner model is the 7170
I am working on getting you a part number and will get it asap.
The printer shouldn't be too hard to open. Screws on the outside and I can help you along the way
Posted on May 09, 2008
  • Benjamin Patri
    Benjamin Patri May 09, 2008
    So after calling Lexmark, this is what I was told.
    You can't get a replacement part, they don't sell them.
    I spoke to Nathan and he told me to call 1-800-358-5835 where you can tell them that he said that you can get, if you ask, 20% off and get free shipping on any All in one Inkjet printer of your choosing which may require you to trade this one in but there isn't much other options unless you can find another one to salvage parts off of since I couldn't find any place otherwise that sells that specific part.
    Let me know what you think, I am always happy to hear a little feedback
    Please Have a Good Day.
  • Benjamin Patri
    Benjamin Patri May 18, 2008
    Please let me know if you have any further questions so I can get you on your way.
    If not, then don't forget to rate my solution as any feedback is appreciated.
    Thanks, and have a good day.
  • 813 Answers
Can u spacife your scanner model no
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
Blank copies from copier
You don't say what model your fax is.
In general. If when copying you get a Full BLACK page printed then the scanner lamp is not lit. As no light is reflected into the image scanner, it interprets this as BLACK information so therefore only black is printed. Look into the ADF while the document is being scanned and I bet you will see no green light at all. A new Contact image sensor should cure it.
Jan 13, 2014 | Canon Duplex Automatic Document Feeder
I have a new bizhub C224 when I print color is OK but when I copy color there is magenta lines or cyan lines and only in copy and the demo page is ok too
Problem with the scanner (Thing that move as it scans has the bright light and mirrors on it. Or the CCD that is the black device under the big glass on the right, get a tech out to clean and or replace
Dec 26, 2013 | Konica Minolta Bizhub C224 Color Copier...
When i print out a paper, there is a black line through the print out.
I am assuming your black line is printed (not smudged ink)...
If your printer is also scanner/copier, try copying a page (rather than printing from computer).
If it scans & prints ok, it could be communication/driver problem. Try reloading the drivers and see if it improves. If the black line is there when copying as well, there's probably not much you can do about it.
hope this helps
LC
www.inkbank.com.au
Nov 10, 2010 | Brother Office Equipment & Supplies
Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
May 10, 2010 | Konica Minolta Office Equipment & Supplies
When copy a document, it will scan but the print out page is blank. I tried replacing the toner but got the same problem. The unit is still 3 months old so i think the drum is still ok.
I know it sounds simple, but do you notice the scanner light on? Open the cover and try a "sky shot." The copier should print out a black page. You'll also see whether or not the light is on and the scanner is moving.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Scanner and copier do not work
In your case, the scanner light is not lit during the scan or copy. If you print something from the pc, it would print just fine. Try to powercycle the printer, then try copying again. If it persist, scanner is defective but you may still use it to print from pc.
Mar 05, 2009 | HP PSC 2355 All-In-One InkJet Printer
Copier feature (Black or Color) only produces a Black page
I beleive you are not able to make a color copy, once try to scan from the computer or all-in-one to check whether the scanner mechanism is working properly or not, if the scan comes out fine then remove the color cartridge and clean the copper contacts of the cartridge with soft cotton cloth and also check the ink level of the cartridge, if the issue persists replace the color cartridge and if even the scan does not comes out good then there is an issue with the scanner mechanism.
May 14, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Mar 21, 2008 | HP PSC1510 Printer/Scanner/Copier...
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
122 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
