My pc boots and stops after 5 minutes what is likely the problems & the resultant solution
  • 27,725 Answers
Test your PSU or replace it
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Posted on Aug 30, 2010
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Booting up issue
Does it do this with the mains charger connected or only on battery power?
The plugging in the mains charger if not already, wait a couple of minutes and then try switching it on.
If the boots up fine you more than likely have a battery problem.
If it still doesn't start then you either have a power supply problem on the laptop itself or your main charger is faulty and not charging the battery.
You can also remove the battery and try booting it with only the mains charger connect.
Please provide the results of these queries
Mar 19, 2012 | Acer eMachines 520-2890 Notebook
I turn my pc on and it come on but it wont boot up. After several times of turning it on and off it boot up but tell me the system is fixing the problems. Aftrer about 5 minutes of the system fixing...
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
http://net2go.blogspot.com/
Feb 26, 2011 | HP PAVILION M8200N PC Desktop
Dell T3500 with E139765 on motherboard. LED on motherboard is yellow & system will not boot up.
Try the steps given below and it should resolve the issue;
1. Turn off the computer - unplug the power cable
2. Press and hold down the power button for 1 minute with power cable unplugged
3. Release the power button
4. Reconnect the power cable and turn on the computer
5. Dell ought to boot in Normal Mode
Lemme know the results.
Regards,
Anirban Mazumdar
Dec 04, 2010 | Dell Precision T3500 Computer Workstation...
Magicolor 2430 DL Fatal Error Code: 12H
I advice you power off the magicolor 2430 DL and power on after few minutes, while the magicolor 2430 DL is loading or booting, pull out the plug from the AC outlet and wait for minutes before plugging it back and power on, if the problem still per, press the stop button for about 5 seconds and release, see what happens, if it fix the problem.
Let me no what happens.
Take care.
Jul 10, 2010 | Konica Minolta magicolor 2430 DL Laser...
My car hyundai elantra 1998 stopped while running , i towed the car to the house & tried to start , it started in 1st self & stopped again after 5 minutes. then I changed oxygen sensor &...
It might have something to do with your mass/air sensor located on the intake tube. Try cleaning the mass air sensor with the appropriate cleaner and also try cleaning the throttle body with carb cleaner.
Jun 08, 2010 | 1998 Hyundai Elantra
Come on, boots up, then shuts down 5 - 10 minutes later.
check your power options make sure you don't have hibernation enabled, its in the system control panel. try booting from a linux live cd like Ubuntu which you can download for free. If it runs fine under linux, its a windows problem, if it keeps shutting down its a hardware problem. Could be bad ram, or CPU overheating.
May 09, 2009 | Computers & Internet
PC Cannot Boot
Common windows problem,you need to wipe your drive and reinstall your operating system
Jan 08, 2009 | MSI K8MM3-V Motherboard
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
My compaq laptop freezes after 30 minutes
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. Have you expierenced that problem also? There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Nov 27, 2007 | HP Compaq nx6110 PC Laptop
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
