Question about Haier HDY6-1 Electric Dryer
L have a HDY-C70 condenser model , the room steams up and condensation is running down the walls, we drain the water collection container after every load.
I have the same issue, i have had a service tech in and he claims to have fixed it though the problem nremains.is your dryer in an enclosed space??
Posted on Jan 22, 2011
Water accumulating inside the fridge
hi kostas.
Condensation runs down the back of the fridge and collects in the gully sitting at the back of the fridge where the water is then channelled through the drain hole into a container which sits on the compressor, it's then evaporated away.
How to Stop Water Collecting in Your Fridge ' eSpares
https://www.espares.co.uk/advice/.../how-to-stop-water-collecting-in-your-fridge Water accumulating inside the fridge Google Search
Nov 07, 2017 | Refrigerators
Hi there, have a Hisense fridge model hr6tff526(s) which is leaking water from the inside,looks like its coming from the top where the fan is located.thx
Hi Kassem
It's probably just condensation water like what you get under an air conditioned car in the summer.
Usually in a Fridge they collect the condensed water and run it down a clear hose pipe to a plastic container at the bottom rear of a fridge.
This pipe can become blocked with food & junk & mould, mice etc.
Find one end and clear the obstruction. A flexible rod or wire or air burst.
Cheers
Example Repairs:
DIY troubleshooting and repair for RV refrigerator condensation drain tube...
How To Clean Air Conditioner Drain Water in Drain Pan
Fridge Leaking Inside Refrigerator Drips From Ceiling Defrost Clogged...
Sep 14, 2016 | Refrigerators
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
Need to know if I can connect a drain hose/tube to my air conditioner model # FAX054-P7A1. I'm having a problem with water collecting in the window sill/track
Hello, the first thing is make sure the AC is tilted a bit in the window, if it is level the water will collect toward the front of the unit and drip inside. Second if there is a drain hole on tne unit then you can connect a hose to it and let it drain. However if there is no drain hole then the unit uses tne fan blade to splash the water on the condenser and since the condenser is warm/hot it will condense the water.
Jun 08, 2011 | Frigidaire FAX054P7A Wall/Window Air...
On cooling the pan fills up in 2 hours. gets hot in the night having to empty it all the time plus no sleep.
I cant help you with the sleep part ... is there a way you can fasten a drain hose to the collection container?
Eventually, you will get the water out of the air in the space you are cooling and the filling of the container will slow down.
The way I see it your options are: (1) keep doing what you are doing (2) get a bigger container (3) find a way to drain the condensate away to a drain or other place where the water can be collected and pumped away.
You could turn the AC off at night ... that way there would be no condensate produced.
Thanks for your question @ FixYa.com
May 30, 2011 | Heating & Cooling
Mr Slim is dripping condensation into the room. I use this to heat and cool a 500 sq ft finished space over garage. I have been looking for troubleshooting guides but no luck. It is cooling the space,...
Firstly i would try and establish if the unit is on a gravity drain or a pumped drain.
1. If the drain is gravity it means the condensate water will flow with gravity normally straight through the wall, so check for blockages outside and inside, the unit may look clean but if it hasn't been serviced there may be a build up of dirt in the drain.
So try and locate the outlet of the drain outside (normally by the refrigeration pipework to condenser) and attach a wet hoover to it and make a good seal, this will **** any water/dirt out of the drain line.
2.If its on a pump, a small water pump which collects the condensate in a sump and then pumps it away when a float is activated. (Normally fitted if a gravity drain option is unavailable).
You can check to see if the sump is full and overflowing which is an indication the pump/float has failed and will req replacing by an A/C company. Or the PVC drain line is blocked with dirt.
The pump is either located behind the unit in the casing, or in the white trunk containing the refrigeration pipework
All the best
Jul 05, 2010 | Mitsubishi MSY-A15NA Split System Air...
WE have an older fridge. Water is now collecting
Good day,
On some of the older models when the refrigerator went thru it's automatic defrost cycle, the condensate water ran down the back wall, under the crispers and out that drain plug you described.
You can verify if that is your model by looking at the back wall of the machine. If there is no drain tube running down the back, then that is the model you have.
If that is the case, just remove the plug. The water should run directly into the drain pan.
Clean the plug and opening and that's it.
Apr 05, 2010 | Maytag Admiral Top-Freezer Refrigerator
Water collects under the veg tray on bottom of fridge
Good day,
That's a classic example of the drain system either plugged up or iced up.
Remove the rear panel in the freezer, and inspect the drain hole where the condensed water drains out of the machine. Must be blown out or de-iced. Service techs use compressed air tank with hose to blow out the dirt. You'll need to improvise. However...
There are a few models that let the condensed water run down the back wall of the fridge, under the crisper drawers and then out a drain plug.
Check for this first.
Nov 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
TFX25PR TFT25 PR GE Profile 25.2 cu ft no frost Serial GS248611 Model TFX25PRYD WW Water collecting and freesing in bottom of freezer side and running out the front, Drain tube at back is NOT...
Here are som links that will be helpful. I believe ice is blocking the defros condensate dran behind the freezer back wall of the freezer compartment.
Here are some helpful links.
http://appliancejunk.com/forums/index.php?topic=22.0 and http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/ Pour a warm solution down the drain with Clorox and I think that will help too. Hope this helps. Thanks, Sea Breeze
Jul 28, 2009 | Refrigerators
Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Mar 15, 2008 | Refrigerators
Haier HDY6-1 Electric Dryer Logo
155 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Bill Long
Are you a Haier Dryer Expert? Answer questions, earn points and help others
