Question about Magellan eXplorist 600 GPS Receiver
Replacement keypad membrane
I am looking for a replacement rubber keypad membrane for my eXplorist 600. Can you help?
  • 3 Answers
If you look on magellan website it states they no longer have or support replacement parts for older gps models.
You can find an explorist for parts on ebay.
I own a explorist 100, 400, 500. I believe the key pads are all the same. If you can not find one, I will sell you the pad from the explorist 100 for 30 dollars plus shipping.
Posted on Jul 17, 2008
The keys have frozen and i can not get it to start up again
You have to dissamble the fax machine front panel keys, then check if the membrane rubber is still good, clean the pressure pad and the pcb copper with an alcohol, a dirt will cause that trouble. Resolder all the keypad.
It still has the same trouble then the front panel keypad pcb board is need to be replace.
I hope I help you to your problem.
Jun 05, 2011 | Office Equipment & Supplies
I have a Dacor double oven that gives a error message of F0 and then shuts itself off.I don't have the manual so I don't know what this error code means or how to fix it.HELP!
F0 means shorted keypad or stuck key on keypad.
Solution: The membrane aka keypad has to be replaced.
There's a slight chance that the ERC aka oven controller is acting up also.
So safest bet replace both, ERC and membrane.
Dec 24, 2010 | Dacor ECD227 Epicure Electric Double Oven
After cleaning oven now it shows F 3 and will not work
F3 on a GE means you have a shorted membrane keypad.
There are two ways to fix this model, either replace the membrane keypad which is a lot of work (handy guide with pictures) or to replace the complete controller.
It's probably not going to be economical even to repair it yourself if you or a friend want to. It depends on the model:
JES1334WD001
JES1334WD01
JES1334WD02
JES1334WD03
JES1334WD04
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
I looked up parts prices for the -02 verison.
ref # 38 part number WB27X10554 membrane keypad $69.71 here (compared to $112.50 direct from GE!)
ref # 42 part number WB07X11076 complete controller assembly $131.01 here (compared to $196.25 direct from GE!)
Oct 27, 2010 | Ovens
I want to buy a replacement battery for my Magellan eXplorist 600. How difficult is it change it? How do I do it?
Try this address http://www.magellangps.com/assets/manuals/eXplorist_600_en.pdf I checked the manual looks like it is real easy, just not sure where you get the battery from. Hope this helps
Apr 01, 2010 | Magellan Replacement MAGELLAN EXPLORIST...
Replacement parts for Magellan eXplorist GPS
You need to be brave, but it is pretty simlple. Basically you are going to clean the rubber keypad and circuit board contacts. These contacts develop a film over time that needs to be removed. That is the main reason telephone and remote control keypads fail over time.
1. Remove the battery.
2. Remove 5 screws holding the bady together and separate the backplate from the main body.
3. Now carefully lift the circuit board out of the main body. Do not disconnect anything, but be careful with the rubber seal that fits between the back and front plates.
4. With the circuit board laying flat on your work surface, remove the rubber keypad. It is held in place over the joystick. Carefully lift it off the joystick and set it aside.
5. Use a clean pencil eraser and lightly rub the contacts on the circuit board. Do the same thing on the keypad by pushing the little knobs out where you can rub them. Blow away the dust.
6. Use a Q-tip with some alcohol to clean the contacts on the curcuit board and on the keypad.
7. When the alcohol is dry, put everything back together in the opposite order.
This should be good enough, but if it does not solve the issue, then buy a rubber keypad repair kit (an example is at http://www.mgchemicals.com/downloads/appguide/appguide0206.pdf) and try again.
Good luck.
Sep 02, 2008 | Magellan eXplorist 400 GPS Receiver
Sanyo CLT 947
Two solutions. Replacement rubber key pad membrane or re-apply conductive coating.
1) Call Sanyo and see if they have a replacement rubber membrane keypad for your model of telephone. (I replaced the keypad membrane on my Sanyo CLT-2430 cordless phone). In Canada, the Sanyo telephone number is: (905) 760-9944. Their web page is: sanyocanada.com.
2) A rubber keypad repair kit is available from MG Chemicals. Rubber Keypad Repair Kit 8339.
This kit is described on their web page: http://www.mgchemicals.com/products/8339.html
In Canada, this keypad repair kit is available from ElectroSonic. See a description of this kit at: http://www.e-sonic.com/acc/products.aspx?command=detail&partID=8339&partIDExt=281
In Canada, this keypad repair kit costs about $14.00.
Apr 22, 2008 | Sanyo CLT-A902 Cordless Phone
Magellan explorist 600 gps with windows xp
It is more than likely a defective USB cable. I am on my third cable. They don't stand up to the abuse.
Apr 03, 2008 | Magellan eXplorist 600 GPS Receiver
Rubber keypad membrane unglued
what I did was i went to walmart and brought rubber cemment..and a very thin paintbrush..and i just touched it up some areas and closed the sidekick screen over night..and that did the trick for me
Sep 23, 2007 | T-Mobile Sidekick II
Magellan eXplorist 600 GPS Receiver Logo
206 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
